Old 08-30-2010, 12:01 AM
peter.blais is on a distinguished road
Face milling thin stock....
Hi guys.
I've got some parts which are made of 1/4" 6061, and machined down to like .2" .
Anyways, the stock is wide enough that if you hold it between vise jaws, it vibrates like hell.
To combat this, I made a 24" long plate out of 1" thick 6061, 8" wide. I machined the center out and have a slot full of pitbull clamps holding down two 3" wide strips of stock.
Anyways, I really thought this would give me a nice finish, like when I machine nice thick stock. The stock doesn't have much evidence of chatter- and there's no sound, but the face mill marks up and down the plate are inconsistant.
Anybody have any insight about this? I'm thinking perhaps I got a little carried away with the pitbull clamps, and I'm bowing the plate up slightly- but I played around with the torque on the clamps a bit and it doesn't seem to make any difference.
I'm afraid of having the stock come out and wrecking my favorite face mill lol.
I'll post a picture of the setup tomorrow at the shop and the results.
Old 08-30-2010, 01:19 AM
Matt@RFR is on a distinguished road
What style inserts are you using in your facemill? What DOC, speed and feed are you using? In my experience, the absolute worst thing you can do in your situation is feed a facemill too slow.
There is a lot of talk lately of very poor aluminum being sold. Could this be part of your problem? Do you have any other 1/4" thick material that you've had good results with, that you could cut down to your current size?
Also, you might post a picture of the finish you are getting.
Old 08-30-2010, 01:58 AM
austin.mn is on a distinguished road
I do a lot of thin stock machining. You need to tape it down with carpet tape, then clamp it. It should make a big different on your finish.
When I first started engraving thin aluminum, I would break tiny bits on the finish pass. For some reason no matter how light I program the cut it was always way to deep. I found that when you relieve the stress on one side of the material it will tend to bow upward. If you stick the part down with a little double sided carpet tape it will keep the material from bowing and keep it from vibrating.
Old 08-30-2010, 11:45 AM
dougtyler's Avatar
dougtyler is on a distinguished road
Google the name "mitee grip"
Its a waxy type material that you can use to bond your part to a sub plate.
This stuff works awesome. just heat up your subplate and part to 200 degrees. (I use an electric grilled). Then place the part on the subplate, apply weight to keep it held down while the assymbley cools off, and your good to go.
This stuff has a holding strength of 40 psi.
When your done machining just heat it back up to 200 degrees and the part will fall right off.
Old 08-30-2010, 12:42 PM
hitachibos is on a distinguished road
i have done alot of this type of work and i agree with Austin.mn use TAPE. but there is a secret to what else he is saying. "I found that when you relieve the stress on one side of the material it will tend to bow upward."
what you need to do is find the natural bow in your material put 2 strips of 2" tape on a subplate that is flat and clean (use alcohol to clean the plat and stock)
lightly place your part on the tape so the edges bow upwards. (like a bowl)
The middle will stick to the tape. Now in the corners at least, place shim stock under to take up the air gap. (you can do the edges too)
Cut the surface but only clean up the top to about 75% clean <- i mean most of the surface will be cut and some will still be raw material. THIS is the key IF you cut the whole surface now it WILL BOW
Spray alcohol around and under the part to loosen the tape.
now put tape on your part first where it took a chip and cleaned up.
place your taped part down on the subplate and cut this side complete until you clean the whole surface.
unstick it and flip it one last time use tape again and bring you part to thickness. cleaning up the origonal side you started with.
if all goes well you will have an extreemly flat piece when done with NO bow.
Good luck.
Old 08-30-2010, 12:44 PM
remember 3 flips for flat
Old 08-30-2010, 12:55 PM
Here goes:
The face mill is a mitsu. ASX400 with their HTi10 aluminum inserts in it. It's a 4 insert 2.5" cutter and feeding 80ipm @ 3500 rpm for finishing. This has given excellent finish on thicker material. I tried faster / slower on the feed and rpm, nothing seems to improve it much.
I don't think the material is an issue. It's from a local extrusion house about an hour down the highway- we've machined a lot of it in thicker form and not had any issues. I did make some parts a long time ago using some thin alcoa, and it was fine. I held them differently though.
I'm a little leery of tapes / adhesives because I was sort of figuring this out for an upcoming run of 1000pc of something else... I don't really want to be heating / cooling that many pieces or "trays". I suppose if I made a sub plate / dowel pins setup, I could be heating / cooling while the machine runs.
To the gentleman who suggested carpet tape- what is your procedure between batches?
In the past, I drilled extra holes in the stock, in areas which would be machined through later- and then used flat head allens just below the surface, and this gave excellent surface finish. It's also a pain in the ass as those bolts need to be removed and the parts secured down through the permenant holes for machining the profiles etc.
I attached the pictures of what I'm getting. The actual finish isn't bad, but I can tell the part is deflecting because the tool lines move around on it. I haven't spent a lot of time with a mic on the finished part but i can only assume the finished part also includes high / low spots to some degree. I did check quickly and the parts produced would be acceptable, I'm just not happy with it.
I did try a few different torque settings so to speak on the clamps. I'm afraid of loosening it up any more and having it pull out & wreck my inserts / face mill. I've never used the pitbull clamps before so not much experience here on how tight they need to be.
ID:	113684   Click image for larger version
Old 08-30-2010, 12:58 PM
PS: The piece of stock shown is from before the fixture had those extra drill holes and circles machined into it. I'm facing one side, then flipping it over and facing / drilling / pocketing.
Old 08-30-2010, 01:35 PM
BobWarfield's Avatar
BobWarfield is on a distinguished road
You can also use superglue. Heat will make it release, but use good ventilation, because the vapors are toxic. It's very fast to lay down superglue.
A vacuum fixture might also work for your application, but it would be more trouble to make one. Still, for 1000 pieces, it might be worth it.
Cheers,
BW
Try G-Wizard Machinist's Calculator for free:
http://www.cnccookbook.com/CCGWizard.html
Old 08-30-2010, 01:53 PM
osphoto is on a distinguished road
Thank you for the suggestion of mitee grip!
  #11   Ban this user!
Old 08-30-2010, 08:15 PM
fuzzyracing1967 is on a distinguished road
Something else you may want to try, since you mention 1000 other parts, would be to make vice jaws that are the length of your part. In your picture you show 2 vices,so you make step jaws as long as your part,your jaws are then bolted to just one vice and the 2nd pinches the jaws. This way your stock is held the entier length and can be changed in and out quickly. However this does only work if you stock is straight to start with, (within reason).Just a thought
Just push the button,what's the worst that could happen.
  #12   Ban this user!
Old 08-30-2010, 09:05 PM
Cmailco's Avatar
Cmailco is on a distinguished road
Question
What are your requirements for flatness and finish?
The Manufacturing Reliquary
http://cmailco.wordpress.com/
milling deep thin slot dlenardu General Metalwork Discussion 7 01-25-2009 08:23 PM
Need Help!- Milling Deep, Thin Slots divinecnc General Metalwork Discussion 1 01-23-2009 10:31 PM
Problem- milling thin wall brass tubing jackie_burton@m General Material Machining Solutions 11 09-29-2008 03:46 PM
Help with face milling... peter.blais General Metalwork Discussion 18 09-24-2006 01:20 PM
Save 100% on Tooling cost and set up time on milling thin parts with the Doo-Bee Stop DynaPowernamics Product Announcements & Manufacturer News 5 05-28-2005 09:17 PM
