Old 08-26-2010, 09:28 PM
aadrew10 is on a distinguished road
What is this buzzing thing on the back of my Mini Mill?
Can anyone tell me what this black box with the two wires coming out of it is? It is just to the right of the pressure gauge. Every so often is starts buzzing, and then shuts off. It seems to be sending an air/oil mix up to the spindle.
Also, what is the big thing made by parker in the second picture? Is that a dryer or a filter or a coalescer?
I'm new to this stuff.
- Andrew
ID:	113483   Click image for larger version
Old 08-26-2010, 09:37 PM
jeffrey001 is on a distinguished road
Look to me like the system to remove water from air line.
Compressor made a lot a water and this is where it is remove
Jeff
Old 08-26-2010, 10:17 PM
Donkey Hotey's Avatar
Donkey Hotey is on a distinguished road
Yes.
Greg
Old 08-27-2010, 12:31 AM
Can anyone tell me what the thing in picture 2 does? I am wondering if it is something I have to take apart to clean/drain periodically.
Old 08-27-2010, 02:00 AM
http://www.cnczone.com/forums/showthread.php?t=93214
Maybe this will help.
Jeff
Old 08-27-2010, 02:26 AM
The big thing made by Parker is the air pressure regulator which reduces the incoming supply to 85psi. You should never have to clean it if you have dryers and filters on your air supply. If you do not have dryers and filters you should install them before you start getting solenoid valve problems.
Old 08-27-2010, 04:48 PM
Does it mean anything if the piece with the dial in the first picture starts leaking out the bottom? I put my finger under it and it is dry air, there isn't any condensation in it.
I have a dryer at the compressor, but I can still see moisture in the line after it. I'm going to replace it. Does anyone have a recommendation on a good dryer?
Need Help!- mini mill back lash adjustment? Micro Milling Benchtop Machines 2 12-29-2009 06:04 AM
Need Help!- Super Mini Mill 2 Buzzing from Air filter/regulator Gabe Newell Haas Mills 4 09-01-2009 03:43 PM
Datron mill, any thing similar? Dark-Angel General Metal Working Machines 0 11-13-2008 10:12 PM
Buzzing from the back Babba Syil Products 8 10-29-2007 11:50 AM
Small Mill Part/Project/Thing Showcase BrendaEM Benchtop Machines 5 08-01-2007 12:25 PM
