Old 08-21-2010, 10:48 PM
aadrew10 is on a distinguished road
Can I Add These Options to MiniMill later?
Hi Everyone,
Can somebody let me know if it is possible to install a chip auger and programmable coolant on my 2004 mini mill? What kind of retrofitting would it take... a new board? Also, what needs to be done to gain 4th axis capability?
Thanks,
- Andrew
Old 08-21-2010, 11:27 PM
certifiedtech is on a distinguished road
upgradable
Your mini mill will not need a new IO board for the P cool It will just plug in to the existing board. You will need to run a cable up to the head though. sometimes factory will run the cable and just coil and tie bundle under the head cover. 4th axis is easy just need to buy the 4th axis kit from your local HFO. This will consist of an amplifier and cables with two plugs for mounting on side of electrical cabinet. The chip conveyor on a mini mill is alot of work probally not worth it if it wasnt built for one to begin with just leave it be. Hope i helped and good luck
CNC Minimill Project elnerdo EBAY ADS 0 02-04-2010 07:13 PM
8000 RPM MiniMill behindpropeller Haas Mills 2 12-21-2009 04:57 PM
Another MINIMILL post COPO427 Haas Mills 21 05-02-2006 03:49 PM
MiniMill plans ignatz Benchtop Machines 0 02-02-2006 02:10 PM
which minimill for signlab? area51zc CNCzone Club House 0 01-06-2006 04:54 AM
