Old 08-19-2010, 07:29 AM
motorMA is on a distinguished road
VF- 10,000 or 12,000 is it the same motor?
For new machine are the only change the parameters
Same for the rapid feed from 1000 to 12000
If you know, let me know
Michel
Old 08-19-2010, 08:29 AM
When I was looking at the 12,000 rpm option on a VF machine I was told it was a different spindle with higher grade bearings.
Old 08-19-2010, 09:35 AM
GermanTec is on a distinguished road
I think they have a 12K 20HP Motor for the VM Moldmaker machines and the same motor on the VF series without Gearbox and the 10K option. On the VF- the Motor only run 10K about the parameters. But Attention, they have two different 12K Motors with different parameters (Lincoln/Baldor). Have a look on the label from the motors.
The most dangerous phrase in the language is:"we've always done it this way."
Old 08-19-2010, 12:31 PM
JohnJW is on a distinguished road
I think the 12K spindle, if they are same as the ones on the SS and VM, are direct drive while the 10K spindle are belt driven.
Old 08-19-2010, 12:33 PM
Yes, your right, but the question was only about the Motor, not for the spindle.
Old 08-19-2010, 07:40 PM
The 12K ones are listed as 30hp, but the non gear driven 10K ones are listed as 20hp. Are they the same motor? There are plenty of stories about how different manufacturers list their horsepower rating. . . but can the same motor couple to different spindles result in different hp rating?
Old 08-20-2010, 12:39 AM
I've only look on the partnumbers from the motor in the sparepartlist.
In the list is the lincoln 12K Motor for the VM and for the VF, and the Baldor 12K Motor for the VM and for the VF listed.
But I will ask my sparepart specialist for an answer.
Old 08-20-2010, 02:49 AM
The 12K Motors are listed for VM and VF because there are for the VF-SS Inlinedrive. It's not easy to see only in the sparepartlist. I'm sorry, I miss my brain.
Need Help!- Changing Fanuc AC servo driver and motor for a regular VFD and async motor Bordaco Servo Motors and Drives 4 09-08-2011 05:41 PM
Problems with motor stalling due to motor/lead screw alignment Bimmerkc1 DIY-CNC Router Table Machines 3 01-24-2010 06:12 PM
New Machine Build- Mach3 , Config, Motor Tuning problem ( FILM OF MOTOR) MDF_Markazi Mach Software (ArtSoft software) 7 04-30-2009 02:15 AM
replacement motor for PML&Kollmorgen DC Brush Servo Motor fymroger Product Announcements & Manufacturer News 2 10-24-2008 03:36 AM
servos motor controled by stepper motor driver? mike10 Servo Motors and Drives 1 01-03-2005 05:05 PM
