Old 08-12-2010, 05:22 PM
timmydabull is on a distinguished road
Erratic tool release issue
for the last couple months i have been experiencing an erratic tool release during power up of the machine or when i push the MDI button.
it happens intermittently and when you least expect it the drawbar will start unclamping and clamping non stop,usually resulting in a tool falling out of the spindle.
i have disassembled the z axis cover and cleaned and checked the wires and connections to try and alleviate this problem but i believe it may be some sort of electrical component or circuit.
before i look any further has anyone had issues like this before and what do you suggest?
thank you in advance
2007 Haas TMP-1 Microscribe MX-5 Mastercam X4 Mill Level 3 Surfaces,Solids Seagate 2 tb hard drive AMD 64x2 8gig ram windows ultimate 7 64bit Geoforce 8800 GTX
Old 08-12-2010, 05:47 PM
haastec is on a distinguished road
Check to remote tool release button on the head cover for shorts. If you have coolant leaks in the head, it can cause the switch to short out and behave as described. Also, try disableing the switch and run that way for a while and see if the issue goes away. If it does, replace the switch.
Good luck!
Old 08-12-2010, 08:43 PM
the tool release button on the z axis cover did look a little suspicious. and the connector was covered in goo and could not be seperated.
i will disable the parameter and give sone time to repeat itself.
thank you very much for your advice.
tim
Spindle Brake release issue kentsui Cincinnati CNC 8 04-05-2010 03:33 AM
vf4 wont release tool holder panaceabea Haas Mills 9 08-25-2009 05:02 PM
Mazak VTC-20 Tool Release millerwl71 Mechanical Calculations/Engineering Design 0 11-15-2007 07:59 AM
BP Interact 412 - Tool Release not working dpsol Bridgeport and Hardinge Mills 0 06-28-2007 10:32 AM
Tool Release Button, Ken_Shea Haas Mills 3 08-04-2003 08:27 PM
