Want to run tool comp while circle interpolating a bore. So I can sneak up on it with tool wear comp D. Cutter comp moves after entry moves cause 367 alarm cutter comp interference. I know I still struggle w/ CC moves as simple as the feature seems but I've tried doing different things to try to fool it and still can't do what I want. I can do this with G13 but feel I am wasting moves going back to center. I am profiling a bore with many mini Z moves. Any Ideas? Thanks, Jack |
| try this N10 G00 X0.0365 Y0.25 Z0.1 N20 G01 Z-0.110 N30 G01 X-0.213520 G41 N40 G03 X-0.4635 Y0. R0.25 N50 G03 X0.5365 R0.5 N60 G03 X-0.4635 R0.5 N70 G03 X-0.2135 Y-0.25 R0.25 N80 G01 X0.0365 G40 N90 G00 Z0.1 N100 G00 Y0.25 N110 G01 Z-0.210 N120 G01 X-0.213520 G41 N130 G03 X-0.4635 Y0. R0.25 N140 G03 X0.5365 R0.5 N150 G03 X-0.4635 R0.5 N160 G03 X-0.2135 Y-0.25 R0.25 N170 G01 X0.0365 G40 N180 G00 Z0.1 N190 G00 Y0.25 N200 G01 Z-0.310 N210 G01 X-0.213520 G41 N220 G03 X-0.4635 Y0. R0.25 N230 G03 X0.5365 R0.5 N240 G03 X-0.4635 R0.5 N250 G03 X-0.2135 Y-0.25 R0.25 N260 G01 X0.0365 G40 N270 G00 Z0.1 N280 G00 Y0.25 N290 G01 Z-0.410 N300 G01 X-0.213520 G41 N310 G03 X-0.4635 Y0. R0.25 N320 G03 X0.5365 R0.5 N330 G03 X-0.4635 R0.5 N340 G03 X-0.2135 Y-0.25 R0.25 N350 G01 X0.0365 G40 N360 G00 Z0.1 N370 G00 Y0.25 N380 G01 Z-0.510 N390 G01 X-0.213520 G41 N400 G03 X-0.4635 Y0. R0.25 N410 G03 X0.5365 R0.5 N420 G03 X-0.4635 R0.5 N430 G03 X-0.2135 Y-0.25 R0.25 N440 G01 X0.0365 G40 N450 G00 Z0.1 |
| Try the following... put 0.25 in D01 Geometry offset (INTERPOLATE 0.75 DIA CIRCLE AT 0,0) T01 M06 (LOAD 1/2 EM) G00 G54 X0 Y0 S5000 M03 (POSITION TO CENTER) G43 Z0.1 H01 M08 (RAPID TO CLEAR) G01 Z-0.5 F10. (FEED TO DEPTH) G41 X0.375 D01 F5.0 (FEED TO RADIUS - APPLY COMP) G03 I-0.375 (INTERPOLATE CIRCLE) G01 G40 X0 (FEED TO CENTER - CANCEL COMP) G00 Z0.1 (RETRACT TO CLEAR) |
G03 I-0.375 (INTERPOLATE CIRCLE) you can also add a "Z" and "L" values on this line if wanted to interpolate XYZ simultaneously. "Z" being depth per circle, and "L" being how many times you want to interpolate/multiple depths. say you want to take .125 deep cuts going 1 inch deep G03 I-.375 Z-.125 L8 |
| cut circle | bbrown2005 | Mach Wizards, Macros, & Addons | 2 | 02-04-2009 06:41 PM |
| Problem- circle | AngelT | Mach Mill | 1 | 06-30-2008 08:59 AM |
| The Perfect Circle - Need Help | ScoobyDoo | FeatureCAM CAD/CAM | 11 | 01-17-2007 04:41 PM |
| circle in G-gode | fred klusmann | G-Code Programing | 7 | 01-15-2007 07:21 AM |
