Old 07-31-2010, 04:43 PM
l u k e's Avatar
l u k e is on a distinguished road
Anyone here using Trim Sol E206?
I’m looking for a “green” coolant (for cutting aluminum) if there is such a product. I’ve done some searching and this stuff keeps coming up. I don't know if this is considered "green" but it seems to be environmentally safe which is what I want in my home shop.
I’m assuming this comes as a concentrate but I can’t seem to find mixing ratios so I can figure out how much to purchase.
Just looking for some input on this stuff or some info on a similar product.
Old 07-31-2010, 06:17 PM
djr76's Avatar
djr76 is on a distinguished road
Never used that but I do use Trim Whamex to clean my sumps out, stuff works awesome. So Im assuming other products from Master Chemical are quality metal working fluids. Call your tool rep and get a 5 gal. sample.
Old 07-31-2010, 08:12 PM
hercules is on a distinguished road
I have been using it for about two years. I have had good luck with it. I have never had a batch go rancid and smelly on me and it seems to protect the machine's surfaces well. I use it on my lahtes and mill at around 8-10% concentration and on my cut off saw at 20%. It has a very slight pleasant smell and the solution is a nice translucent blue when first mixed up although it turns milky after a bit of use. It leaves a very, very light film on the machine and on parts. The film is not tacky and the parts wash off easily. I use it on aluminum and steel both, mostly aluminum though. Overall I am happy with it.
Hercules
2008 TM-1, 2008 TL-3, 2009 TL-1, 2010 VF-2YT
Old 08-01-2010, 10:17 AM
l u k e's Avatar
Cool, thanks.
Old 08-01-2010, 10:31 AM
ntcnc is on a distinguished road
There are quite a few coolants out there that are environment friendly, Just remember once you cycle it through your machine it will pick up tramp oil so all the "green" factor is basically gone. You will need some kind of plan to deal with it. Check local lubricant companies to see if they will pick up. Here in upstate NY we have a company called NOCO Lubricants that will pick it up for 1.00 a gallon (that was the price the last time I had them pick up at least) they evaporate the water out and use it for heating oil. If you want to evaporate the water out yourself you can then turn it in as used oil. I personally use my used coolant in my cut off saw and constantly change them out so I never have to deal with a bad sump. Plus it always seemed like a waste to me running new coolant in a cut off saw. The first time you start up on a Monday morning and realize your coolant went bad you will make sure it doesn't happen again hehe.
Old 08-01-2010, 04:22 PM
l u k e's Avatar
What is "tramp oil"?
Old 08-01-2010, 10:15 PM
Tramp oil is way oil that makes its way to the coolant sump.
Old 08-01-2010, 10:37 PM
l u k e's Avatar
got it..
Old 08-03-2010, 08:58 PM
gpcoe is on a distinguished road
We just got rid of it in our shop. It usually worked great for about a month or two and then went down hill really quick. Eventually start breaking taps and poor lubrication on some of our heavier cuts. A lot of shrieking that went away once the coolant was changed out again. Seemed to get a bad smell after the month or two window and usually smelled bad after a long weekend. We are a job shop, so the machines are going most of the time. The new stuff we got is working great without any significant degradation after several months of use. Our test machine was still cutting well after a year of use and we just started converting over a couple weeks ago. It's called Dascool, though I don't recall who makes it and I know nothing of the cost. I don't have any complaints about it yet.
Greg
Old 08-06-2010, 11:31 AM
swain is on a distinguished road
Trim 206
Luke,
I have used Trim 206 for 11 years.
Its usually mixed anywhere from 7% to 10% on a refractor.
When I machine aluminum I keep it lower...around the 7%.
Only problem I have ever had with it is foaming when it gets old.
They do sell and anti foam agent you can add to it...works great.
Our local HFO started advertizing ICE coolant. My buddy down the street with
an aluminum mold shop bought some...and he is raving about it.
No sticky, no foam, ect ect. I plan on trying it on the next machine I clean out.
My .02 cents.
Swain
  #11   Ban this user!
Old 08-06-2010, 01:30 PM
l u k e's Avatar
When you say "old" how long would that be?
Are you happy with it's performance when cutting and tapping aluminum?
  #12   Ban this user!
Old 08-06-2010, 03:15 PM
Wink 206
Luke,
Old to me is 6 months or more. I have never noticed the "bad" smell
I have heard others talk about. The coolant smells good when its first
charged in the machine...and if anything...it loses its smell after two
weeks or so. One difference may be is that I have a tramp oil skimmer and use it alot.
Every 6 months to a year, I empty the cooland tank, clean it out entirely,
and charge with new coolant. I use this both in my mills and lathes.
I have been very happy with its performance..and I machine aluminum and
all kinds of steels. Never had a tap break from coolant that I know of.
Only tap breakage is when I do something outside the box. On the rare
occasion that I am tapping something iffy, I will stop machine and pre-lube
the tap with a thick tap magic bottle for that hole.
Inflation added...my .04 cents.
Swain
g540 trim pot ?? chrisw765 Gecko Drives 1 06-08-2009 03:47 AM
Trim Toolpath help timmydabull Mastercam 3 04-04-2009 01:01 PM
Need Help!- ?s about trim cutting. Stampede BobCad-Cam 6 03-17-2009 11:00 AM
Trim Surfaces weirdharold Mastercam 6 08-15-2008 08:44 AM
Trim john_mccarron EdgeCam 3 11-27-2007 06:42 PM
