| There's a section in the setup manual where you measure the input voltage and connect the wires from the breaker to the corresponding section of the terminal block base on the input voltage. I don't know if this step applies to single phase power setup as well. |
| Yes, low voltage will cause alarms and stop your programs. Everybody is telling you that you have transformer connections and I think they're right. It's the terminal strip on the bottom, right corner of the control cabinet and each set of terminals is marked with the corresponding input voltage. Connect the three wires to the proper terminals and your DC buss will come up to where it's supposed to be.
__________________ Greg |
| I think 'everyone' is not (are not?) right telling you to look for the transformer taps because you will not find them on a machine with the 320 volt power supply. At least that is the case with my TL2. It is possible that you could run the machine on 220 volts, I think the maximum spindle and servo power will be reduced but not noticeably. However, it might be a better idea to get a transformer to bump the supply up to 240. You should be able to find an autotransformer to do this. If you do decide to run on 220 I suggest you occasionally check that the power supply is not overheating but remember to turn off the main power before poking around inside the cabinet.
