Hello everyone , I have a strange problem on my VF2`97 , when I press feedhold when I change tools or when the riggid tapping is right before tapping the machine wont run after pressing cycle start , this isn`t normal behavior for me because I can do that on my TM-01 without any problems , after few seconds after pressing CycleStart I get Spindle orientation fault alarm , my spindle runs fine , the tool changer too , I can do rigid tapping , the one I can`t do is pressing FeedHold , why is that ? Peter |
| The reason is that rigid tapping is timed to spindle rotation and Z position of the head. when you hit feed hold the spindle gets out of time with head position and cannot restart. Once your machine reads the G code for tapping you have to let it go. You can only pause it just before the tapping line that contains the code. On the more modern machines they have overcome this problem.
__________________ We all live in Tents! Some live in content others live in discontent. |
| there might be a setting that isnt right because all of my 5 mills (from 93-03) wont actually let you feed hold in the middle of a tapping cycle. thus no alarm
__________________ thanks Michael T. "If you don't stand for something, chances are, you'll fall for anything!" |
| Mine doesn't alarm out in a tapping cycle, it just will not stop until the hole is tapped. Mine does alarm out if it is about to change a tool though. Only on the Minimill, not the VF-3,4, or 7. I figured it had something to do with the umbrella changer. If it's just a setting change to stop it from doing that I'd like to change it.
__________________ Apparently I don't know anything, so please verify my suggestions with my wife. |
| Need Help!- Feed Hold Problem | metx | Fanuc | 2 | 01-30-2009 10:10 AM |
| Feed Hold | HelicopterJohn | Haas Mills | 10 | 04-24-2008 09:57 PM |
| Feed hold problem | kirby | Fanuc | 11 | 07-13-2007 08:33 AM |
| Door Feed Hold | 1ctoolfool | Haas Mills | 2 | 09-12-2006 09:45 AM |
| What should Feed Hold actually be?? | REVCAM_Bob | Servo Motors and Drives | 4 | 01-22-2006 12:04 PM |
