Old 07-22-2010, 06:40 PM
mishikwest is on a distinguished road
Change position of A axis home
Can't seem to find parameter to change the A axis home position. Need to change it to facilitate loading and unloading a fixture upon cycle completion.
parameter 224 rot axis zero offset doesn't seem to do anything.
Old 07-22-2010, 07:30 PM
Matt@RFR is on a distinguished road
There's no need to change the home position:
(END OF PROGRAM)
G0 G54 Aa.aaa
M30
Or what I do:
(END OF PROGRAM)
G0 G53 Z0.
G53 X-15. Y0. Aa.aaa
M30
Using G53 you can handle jog the A axis to where you want to park it at the end of a cycle, go to the position screen and simply use the value you see in the A axis readout.
Old 07-23-2010, 12:04 AM
CNCRim's Avatar
I don't think you can change the home axis itself with parameter, if you look at rotor motor of the axis you will see the red eye, that is what detect home. make sure you know what you are doing, if intend to alter the home.
Old 07-23-2010, 02:52 AM
Delw is on a distinguished road
Kinda like matt is saying you can use a fixture offset for the A axis at the end of your part program.
Lets say you run G55 on your part program.
at the end
have a G00 G90 G56 A0.0
just jog your A axis to were it needs to be when loading and set your g56 fixture offset.
Delw
Need Help!- How do i get the Fadal to show my zero position instead of its home position? DSUDS Fadal 4 10-28-2009 12:39 AM
Need Help!- Z axis home position reset Paul in OK Haas Mills 9 05-13-2009 08:05 PM
Change TL-1 Home Position jmanjohns Haas Lathes 3 06-18-2008 04:56 PM
EMC bug? axis position values instantly change after end of program davidma LinuxCNC (formerly EMC2) 5 12-01-2007 04:11 PM
Z Axis Home Position Problems JMFabrications General Metal Working Machines 3 10-24-2006 10:58 PM
