Old 07-19-2010, 07:15 PM
Vern Smith is on a distinguished road
Deburring the back side of a hole
I have a situation where I drill through 2 layers of 6061 with a .400 gap between them. It's a pain deburring them by hand and I was hoping I could deburr them with a reverse boring cycle. My first question is what type of boring bar would you get for this job? I thought an internal threading tool for lathe applications might work OK.
My second question, is there a better way to do this?
Vern
Old 07-19-2010, 07:34 PM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
interpolate it
its pretty easy to do it with a lolypop mill .
if the hole is big enough then a double angled mill works well on flat surfaces .
or its easy to hand grind an old endmill if your in a pinch
A poet knows no boundary yet he is bound to the boundaries of ones own mind !! http://cnctoybox.org
Old 07-19-2010, 07:35 PM
GeorgeRace is on a distinguished road
I wonder if the holes you are drilling are large enough to be milled with a small tool. That would probably stop the need for any deburring.
Just a thought.
George
Old 07-19-2010, 08:35 PM
beege's Avatar
beege is on a distinguished road
Also look into Cogsdill back chamfering tools
Old 07-19-2010, 10:11 PM
HelicopterJohn's Avatar
HelicopterJohn is on a distinguished road
Cogsdill
Hi Vern,
I second Beege's suggestion.
What size hole are you drilling? I saw a guy on e-bay that offered a bunch of used ones in various sizes.
http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWAX:IT
My friend Francesco used them on his project on 1 inch square tubing 1/16 wall thickness and they worked really nice.
We used them in my HAAS TM-1P.
2007 HAAS TM-1P OneCNC XR4 Mill Pro. Shopbot PRT running Mach3, 2010 Screen Set, Super PID and PMDX Electronics. Check out my Gallery on: http://www.helicopterjohn.com/
Old 07-20-2010, 01:50 AM
Delw is on a distinguished road
Vern
the back chamfering tools are nice, but they dont repeat very well, the ones that close when going into the hole then open when spindle is in reverse. sometimes they stick open if chips get in the way and ruin your bore as well as pill the part out along with tool.
I use 45º cutters from harvey tool or a tool grinder cuts them for me. there fast and rigid. solid carbide. thet are like a threading tool but with a 45 degree angle on them.
IN a pinch I have used a solid carbide lathe threading bar(micro 100) to just break the burrs off were the angle wasnt a big deal. its a single sided cutter and runs off center so you need to be carful and not crank the rpms up
Old 07-20-2010, 08:30 AM
I appreciate all the suggestions, I should be able to get it done with this selection Is there another name for lolly pop mills?
Old 07-20-2010, 09:22 AM
djr76's Avatar
djr76 is on a distinguished road
http://www.ezburr.com/index.php
just bought one for the first time and it worked great
Old 07-20-2010, 11:14 AM
Matt@RFR is on a distinguished road
Undercutting endmills.
http://www.harveytool.com/products/i...&category_id=1
And here is what DelW is talking about I think:
Lakeshore Carbide is a distributor for Harvey Tool.
Old 07-20-2010, 07:09 PM
Thanks, I'll call Carl at Lakeshore.
  #11   Ban this user!
Old 07-25-2010, 09:53 PM
offsetxyz is on a distinguished road
chamfering (deburring) the back side of holes
If the reach is not too long and the hole not too small (smaller than .308 inches) a P H Horn boring bar can the programmed to drop in and go around the bottom. It can also go in between the two inside the gap. PH Horn makes two sizes of boring bars in 3 different lengths. The inserts are on 45 degrees. They also make 3 and 6 pointed tools for chamfering with circular iterpolation. Of course you can make a bar to fit your jobs.
  #12   Ban this user!
Old 07-26-2010, 12:38 AM
not a bad idea but the problem with lathe boring bars is they are not balance for a mill. slow RPMS should be no problem.
Need Help!- Drifting X-axis, making step ladders one side whereas other side is smooth- SOS Khalid DIY-CNC Router Table Machines 13 07-13-2010 11:23 AM
side mount tool changer-I take back what I said about 1ctoolfool Haas Mills 25 03-12-2010 10:04 AM
Need Help!- Getting end mill back in already milled hole? Micro Milling General Metalwork Discussion 4 02-02-2010 10:00 AM
Need Help!- Help cuttting from the back side?? Skin Mastercam 78 04-16-2008 08:45 PM
Z-axis - mounting rails on spindle side, rather than tower side guru_florida Linear and Rotary Motion 7 01-31-2008 06:54 PM
