Old 07-19-2010, 08:29 AM
MIKEPETTY is on a distinguished road
npt thread milling help
I'm needing some help writing code for a npt thread. Machine is vf3 and I will be threadmilling. Ive done threadmilling but not ever npt thread. Thanks.
Old 07-19-2010, 09:14 AM
JWK42 is on a distinguished road
Some people say just use a NPT endmilll with the right taper built in and mill just like a straight end mill. We have used this method for 20 years. Some people say you have to follow the taper outward as you mill the thread.
I have a macro NPT milling routine that does that. You will have to have Macros active on your control. If you PM me your E-Mail I can send it to you. I also have a Macro to do straight threads you can have. It probably depends on the degree of error you can stand and how much pressure is on the joint.
You can do a search and find a thread from several years ago that had a lengthy discussion about both methods.
Edit added link
http://www.cnczone.com/vb...illing-178821/
Old 07-19-2010, 12:05 PM
Thanks I'll give that a try.
Thread Milling kdog1972 General Metalwork Discussion 4 11-11-2011 09:33 PM
Thread Milling Don Clement Tormach PCNC 23 08-01-2011 06:48 PM
Need Help!- Thread Milling Doubleddaved Haas Mills 4 09-12-2009 09:05 AM
Thread milling wjfiles General Metalwork Discussion 2 01-08-2007 04:13 PM
