Old 07-14-2010, 11:42 AM
AndyF is on a distinguished road
Macro Help
I'm writing a program for a family of parts, and I'm trying to get the machine to turn block delete on inside the program assuming that a different variable is a certain number. Here's what the beginning of my program would look like:
O00001
#501= 3 (this is a changing number depending on part number);
IF [ #501 LT 7 ] THEN #3032= 1; (This is where I would want block delete on assuming that variable #501 is less than 7).
The problem I'm getting with this is that it alarms out and says it (#3032) is a read only variable, though it's not listed as such in the Haas manual. I tried to unlock variables as well to no avail. If there's anything I'm missing, could you let me know?
Thanks,
Andy
Old 07-14-2010, 01:11 PM
JWK42 is on a distinguished road
Can you use GOTO to jump past the lines you want to block delete
Ex. IF [ #501 LT 7 ] GOTO200;
N200 would be the line to jump to
Old 07-14-2010, 01:23 PM
I thought about doing that, but I was looking for an easier way (hey, I'm lazy). The program nests 4 parts together, and each part would have 2 holes omitted from 1-6 inside a G81. It would be no problem, and probably the simplest solution if this doesn't work, but I'm still curious to try to get the block delete to work. Thanks for the suggestion.
Old 07-14-2010, 03:43 PM
christinandavid's Avatar
christinandavid is on a distinguished road
Are you refering to what I would call Block Skip ( / ) ?
If so I would be surprised if you could change the status of that mode when cycle is running (for safety reasons, you don't want to keep flicking it on/off if you are skipping a large number of lines...).
Does it switch on/off freely on Haas control (as does Opt Stop) during a cycle?
DP
Old 07-16-2010, 09:26 AM
Pondo's Avatar
Pondo is on a distinguished road
I thought macros were an option that had to be purchased - like rigid tapping etc. - that came in a package when you bought the machine. If it was not purchased, it won't work.
Not 100% positive on that, but I remember seeing something like that on the purchase agreements.
"difference between Custom Macro A and Custom Macro B" arulthambi Parametric Programing 4 10-05-2009 03:34 PM
Need Help!- Macro A or Macro B On fanuc o-md macrosat Fanuc 1 07-29-2009 06:49 AM
Testing program for Macro (Fanuc Macro B) NickDP Fanuc 2 03-27-2009 03:15 PM
Macro A or B ? tonper G-Code Programing 6 03-20-2009 11:12 AM
Convert Fanuc Macro to Fadal Macro bfoster59 Fadal 1 11-08-2007 11:41 PM
