Old 07-12-2010, 12:19 PM
jbcourt is on a distinguished road
How can I change the machine Zero position for the B plater?
I need to set a new zero position for a 5 axis trunnion.
The B axis machine zero needs to be set to a new position.
Dose anyone know how to do this?
I have checked the parameters and can find anything I understand.
Thank you, John B
Old 07-12-2010, 02:40 PM
Haas__man is on a distinguished road
Why do you need to do this? I'm not sure that its possible. I'm not saying it isn't possible - just not sure. Can't you just use a work offset?
Old 07-12-2010, 03:33 PM
During Power Up/Restart the fixture is a risk getting bound in the umbilical or hitting the door.
attached is a picture of the setup
Name:	haas fixture.jpg‎
Old 07-12-2010, 03:58 PM
Is it posible that a limit switch is what determining where home is making it impossible to be changed?
Old 07-13-2010, 01:08 PM
If you send both A and B axis home b efore you power off, then they should hardly move on start up.
Could you turn the fixture to where you want your zero position to be?
Old 07-13-2010, 02:01 PM
Thank you HAAS MAN,
We have been sending the machine home every night and it works great.
I was wanting to change the B home just to make the process easier. Thanks for your help.
MV-45/40 tool change arm out of position vfsi Mori Mills 21 11-23-2011 11:09 AM
mtm tool change position double a-ron GibbsCAM 2 01-24-2010 11:29 AM
Need Help!- tool change position miand OKK 2 09-28-2009 08:02 AM
Change TL-1 Home Position jmanjohns Haas Lathes 3 06-18-2008 04:56 PM
How to change Tool change position(About MAZATROL T1 control) liushuixingyun Mazak, Mitsubishi, Mazatrol 5 07-07-2007 02:58 PM
