Hey, hope everyone had a great 4th of July. I installed a new X-axis motor and cable in my VF-0 over the weekend. I remember that there is an adjustment that I had to calculate to set a parameter for the X axis to get rid of an alarm 165. I can't find my notes. Thanks in advance if you can help me. Lowell |
| Grid offset? Parameter 125. I don't know about any calculation but I have played around with the Grid Offset until a 165 alarm goes away.
| There are calculations to figure it out but I have never used it. I usually just start changing the number starting with 1500 or -1500 and jump 1000 increments plus or minus until it goes away. Then smaller incriments to fine tune it. A good rule of thumb is for the distance to go register on the position screen shows about .1200" when the axis is done homing itself. FYI - this may be needed if you ever replace a home limit switch also. Just be certain to reset your work offsets before running again. Good luck. |
This reminded me; write the number in Position display for each axis after homing on a piece of paper and tuck it in the pocket inside the cabinet door. Now you have a number to aim for if you ever need to replace a servo, etc.
| NEED HEELP ALARM #414 Y AXIS SERVO ALARM? | PICMAN | Fanuc | 6 | 04-29-2011 05:20 PM |
| Need Help!- 750 ALARM SPINDLE-1 ALARM DETECT (AL11) | PICMAN | Fanuc | 9 | 03-27-2011 06:14 PM |
| Alarm 409-servo alarm- z axis torque alm | jessebpm | Hyundai Kia machine | 3 | 06-14-2010 07:45 PM |
| ALARM shuttle drawbar alarm haas | timmydabull | Haas Mills | 27 | 10-30-2009 08:27 PM |
| Need Help!- DAEWOO 8 Steady rest pressure alarm, External feed hold alarm | doubleeagle | Daewoo/Doosan | 4 | 06-12-2009 03:15 PM |
