Hello, I am looking at the Haas VF-2 mill for a machining application at my company. My question has to do with the x and y axis locations during a tool change. I understand the z axis is fixed during a tool change, can the x and y axis of the table be in any position? I ask this because one of my parts is rather tall and it would interfere with the tool at the z axis at 20" from the table (this is the tool change position according to haas literature). Max z axis to table clearance is 24". Thanks Tyson |
| You can position x and/or y wherever you want. Are you looking at a side mount or an umbrella type tool changer? With the standard umbrella tool changer you need to make sure your work will not go under it to collide with the tools hanging down. Side mounts will swing the tool 4.5" below the spindle. I usually program X+ so when changing long tools I will program a X-3.00 move before the tool change easy as that. |
| The 20" dimension is not your only consideration. How long are the tools going to be? I think the machine is designed so a roughly 4" tool (measured from the gauge line) can get to the table. So if you have a 6" stackup with a drill chuck and a long drill, you're in trouble. This is something you should be talking to a Haas salesman about. Make absolutely sure they understand how tall of a part you're talking about and how you intend to fixture it.
__________________ Greg |
| http://www.cnczone.com/forums/attach...5&d=1126317440 The X travel is lost because you have to be able to move the part away from the spindle so it can come down to the tool change position. You also have to be careful with how heavy your cuts are because part the linear guides that the Z axis travels on when it is above the tool change position are not as firmly mounted as the lower part.
| Need Help!- One more dumb question on Sizing | csmoak25 | BobCad-Cam | 1 | 03-31-2010 06:12 PM |
| Haas TL-x linear guide sizing - Please help! | dareposte | Haas Lathes | 0 | 09-07-2008 02:33 AM |
| ballscrew sizing question | alexis221 | Linear and Rotary Motion | 0 | 03-17-2008 08:53 AM |
| Stepper Sizing Question | TDukes | Benchtop Machines | 2 | 01-12-2007 06:21 AM |
