Old 06-26-2010, 01:21 PM
JohnJW is on a distinguished road
Electrical Connections (Setup)
The VF-2SS was moved 8 or 9 month ago and has been sitting under wraps while waiting for power and air. I finally got power hook up along with a temporary air compressors. . .I follow the installation procedure and power up the machine. So far, everything looks fine and the last program ran was still in the memory.
I noticed the terminal block has a few different connection options base on the input voltage. The building has 208V 3 phase, but last night when I setup the electrical connections I was getting ~214V so I connected the wires from the main circuit breaker to the transformer connection using the 226-211V section of the terminal block. The Vector Drive reading was at 325V and the DC BUS reading at at 230V.. .within the +/- 7VDC range.
Yet, this morning when I check again, I am getting ~211V on the incoming lines. Now I am wondering if the voltage will drop even further during weekday work hours.
For the transformer connection, Should I connect to the 210-195V or should I connect to the 226-211V? I am curious as to why does it have so many different options instead of just one for 208V and one for 230V, and how do they affect the machine?
thanks,
John
Laptop Connections jcbeck84 Controller & Computer Solutions 8 01-04-2009 10:13 PM
stepper setup, Electrical noise ? veteq Stepper Motors and Drives 3 02-07-2007 10:31 PM
Encoder connections ? Idealchip Servo Motors and Drives 12 07-17-2006 01:58 PM
Pin connections for DNC to 4020 Fudd Fadal 5 04-04-2006 02:40 PM
201 connections rickwinters Gecko Drives 0 01-15-2005 01:37 PM
