Old 06-18-2010, 01:13 AM
pit202 is on a distinguished road
Additional rear light
Hi all ,
I am curious if there is a chance to make that the rear light is turning on when I open machine doors and turning off when I close doors.
I changed the light place to front above doors, it is handy when mounting material.
Anybody ?
__
Peter
Old 06-18-2010, 07:59 AM
Haas__man is on a distinguished road
I think the best way to do what you want to do would be to buy the High intensity lighting option (HIL). You should contact your HFO.
Alternatively you would need to mount a push switch on the door that when pressed turns on power to the lamp (Normally open). This would work, however the lamp on the rear of the machine is not really designed for damp conditions and may or may not last very long in that position. The HIL option is much better - but more expensive.
Hope this helps
Old 06-18-2010, 09:02 AM
Install microswitches so they are operated by the door.
Get a 12 volt transformer and use the headlights made for farm tractors; vibration resistant, water resistant and low voltage so when a tool breaks and shatters the light you are still safe.
Old 06-18-2010, 12:28 PM
I though there were a software option that needs be turned on, thanks for all replays I`ll think about switches.
a ring of 200 Led Lights to light up? light source render? Rich05 Solidworks 6 10-25-2008 06:16 PM
RFQ- Small job on a front and rear panel Dougie085 Employment Opportunity 29 04-18-2008 07:17 PM
Rear toolpost operations? zephyr9900 Mach Lathe 4 10-12-2007 04:00 PM
Machine Recommendations Please - Light Duty, Prototyping, Light Production in metal SCG11762 General Metal Working Machines 2 08-27-2007 08:08 AM
Adding rear shaft to MCG ID33004 avale Servo Motors and Drives 7 07-03-2007 04:00 PM
