Old 06-16-2010, 09:43 AM
stan z is on a distinguished road
G91 G28 incremental???
N56 G80
N58 M09
N60 M5
N62 G91 G28 Z0.
N64 M01
( OP 1 PART POCKET )
N66 M8
N68 T3 M6 ( 3/8 FLAT ENDMILL STANDARD )
N70 G0 G90 G55 X2.1812 Y-.9275 S4000 M3
Will the N62 line put the machine in incremental mode and keep it there till another code changes it?
Old 06-16-2010, 09:55 AM
jess fuqua is on a distinguished road
Originally Posted by stan z View Post
N56 G80
N58 M09
N60 M5
N62 G91 G28 Z0.
N64 M01
N66 M8
yes, thats why we cancel every thing out in our start up line.
Be careful of G91 its a powerful tool.
I use that same ending line always.
Old 06-16-2010, 09:58 AM
WayneHill's Avatar
WayneHill is on a distinguished road
The G90 code will change it back
http://www.linuxcnc.org/docs/html/gcode_main.html
Wayne Hill
www.codemangler.com
Old 06-16-2010, 09:59 AM
I was told that this will do the same thing...send the Z home
G49 G00 Z0
Have you ever tried this ?
Old 06-16-2010, 10:17 AM
G91 G28 Z0
G28 Y0
M30
this is what i like at the end of my prog.
M5
M9
G91 G28 Z0
M01
is at the end of my tool change
Old 06-16-2010, 10:30 AM
Thats how I've been programmig at most places I've worked. My current employer is concerned with the G91,even though the G90 is the next line etc. Hes concerned that the g91 will keep the machine in INC mode with the possibility of crashinng.
They program all parts using sub programs and G52 for work shifts its a high volume production shop .
Although we program our fixtures using absolute mode hes concerned that the G91 will cause aproblem. The G49 G00 Z 0 is used in the "safe" macro M9998.
They also have in this program the following
M9998:
G17 G20 G40 G80 G90 M09 M05
M99
This way they just put this at the beginning and end of the program with no worries.
I come along (been here 2 months) and wanna change there perspective a bit but not make too many waves.
Anyways...just wondering if anyone does it any other way other than the G91 G28 Etc....
Old 06-16-2010, 11:24 AM
I think its cool to program different it will make you a better machinist
Old 06-16-2010, 11:54 AM
Machineit's Avatar
Machineit is on a distinguished road
When I learned to program, many many moons ago, I was taught to start and stop each program with a safe line. That way nothing is left modal etc.
The start line is always: G00 G90 G80 G40 G54
This puts you in absolute mode, cancels any modals, and designates the work offset. Unless you machine a lot in other planes, I see no reason to always put a G17 in the line.
The end line is always: G00 G91 G28 Z0. Y0. M05
This returns the spindle to the tool change position, and moves the table to the front (Zero position for Y for part changing) and turns off the spindle.
The line just before the last one is always a simple clearance line;
G00 Z.1 M09
Always works well, for 18 years at least.
You example line, G17 G20 G40 G80 G90 M09 M05, will not work though, as you cannot have more than one M code in a line, but I'm sure you know that.
Cheers---Mike
M9998:
M99
Old 06-16-2010, 01:47 PM
Pondo's Avatar
Pondo is on a distinguished road
Setting 56 will reset the modal G codes at the M30.
You can also use G53 to home an axis
G0 G53 Z0.
The G53 is non-modal, so there is no worries at all like there is with a G91. It is only active in the line it is in. The G53 offset is the machine 0 point.
Old 06-16-2010, 02:32 PM
G49 G00 Z0
Yes this will send Z to zero in the active work coordinate system because G49 cancels length offsets.
This is fine if you have 0.0 as your Z work offset because then the Z axis goes to machine zero.
HOWEVER, many people choose to set the Z work zero at a reference point such as the table or the top of a vise. Now if you just cancel the work offset and the Z goes to the work coordinate zero you may get big crunching noises.
As Pondo suggests use G53.
  #11   Ban this user!
Old 06-17-2010, 08:10 AM
thanks people..I like the G53 best
Need Help!- G91 INCREMENTAL POSITIONING Patches181 EdgeCam 1 02-03-2010 12:34 PM
Incremental tapping in MDI on a TL-2 Geof Haas Lathes 3 10-08-2008 03:00 PM
DIY Incremental encoder bunalmis Hobby Discussion 1 03-29-2008 06:24 PM
Switch to Incremental moldmker BobCad-Cam 3 10-06-2007 09:43 AM
Absolute or Incremental mikede Haas Mills 1 02-03-2007 05:02 PM
