Does any one know if it's possible to instantly clear all tool and work offsets on a VF-1 and VF-0? I'll have 20-30 height and diameter offsets to zero out, along with g54-g59 x,y,z to clear between jobs, and all I can do is select each one individually and press 0, F1. There is no clear all offsets button. Most of the time, I don't bother. But sometimes I'll have a offset in z or a diameter offset that I didn't clear that gets picked up wrong. I am so sick of clearing each offset that if I am using only 3 tools, I will have the entire offset page filled. Also does anyone know if there is a way to insert block deletes into a long section of code without individually putting them in every single line? |
| What donkey sugests only works on the newer controls, I don't know when they changed but I know on are 1999 I have to do the 0-f1 route. I have a habbit of clearing the offsets before and after the ones that are used just so there eazyer to see.
__________________ Just push the button,what's the worst that could happen. |
| /M99 P1111 (When block delete is OFF you jump, when it is ON you don't) This is the first line you want to jump over; ; ; This is the last line you want to jump over; N1111 This is the line the M99 jumps to.
| I've got a small program saved in the controller that will g10 my typically used shifts to 0
__________________ A poet knows no boundary yet he is bound to the boundaries of ones own mind !! http://cnctoybox.org |
| Setting Tool and Work Offsets | Donkey Hotey | Haas Lathes | 30 | 08-31-2009 09:42 PM |
| Best way to set work/tool offsets? | TechCenterTeach | Haas Mills | 40 | 12-29-2007 11:27 AM |
| CNC lathe tool and work offsets | mm4039 | General Metalwork Discussion | 18 | 06-15-2005 11:45 AM |
| Work Offsets | new2cnc | Mastercam | 3 | 04-30-2005 10:04 AM |
| Setting Work & Tool offsets | Shizzlemah | Fadal | 7 | 04-16-2005 12:04 PM |
