1. What is the normal operating temperature for a 7500 rpm spindle on a VF2 (2008 very low hours) after full warm up? (Temp taken inside spindle right after shut down, without a tool mounted) 2. How much backlash should there be on a “new and unused” VF2 on the Y and Z-axis? |
Backlash? Don't know, but there is a spec sheet in the folder with the manual on the back of the control that should say. |
| We checked the backlash using a mag base dial indicator between the table and spindle. The Y-axis moved about .0003" and the Z-axis moved about .0009" The service guy checked it by bumping the table in the direction of the axis we were checking. He said what was more important that the indicator returned to "zero" rather than the measurement itself. He said "if the machine had wear it would not return to zero after you bumped it". He also said the measurement would not be real accurate since the machine was not leveled and bolted down. Does that sound about right? Last edited by l u k e; 06-13-2010 at 09:36 AM. |
| The actual test for HAAS spindles is to run at 7500rpm for 20 minutes. Temperature should not excede 125'f half way up the spindle taper. Most 7500 rpm spindles will be under 100"f. Backlash should be performed by the "push pull test" with the backlash parameters set to 0. How you perform this test is with servos on, a dial indicator on a mag base and attatched to the spindle head castingand the machine in the middle of travel (roughly). For Y axis, set the dial indicator parralel to the X axis and in the T slot. Push the table towards the back and let go. Zero the indicator. Pull the table toward you and let go. The reading on the indicator is the amount of backlash. For X axis, mount something on the table (vise is good) and perform the test above. X and Y axis should be less than .0003" and can be electronically adapted for in the backlash parameter for each axis. Z axis is rather difficault to test because of the different types of counter balance systems HAAS used through the years. Do not over compensate the parameters or you start to get step marks on 4 sides of a circle. Better not enough than too much comp. Jim |
| Sounds like a good machine to me. Haas machines are my preferred machines, I have put my own $ on the line and bought 2 so far with absolutely no regrets. I have run many different brands of machines and do recommend Haas over any others for anywhere near the same price. There are better, but they are way more $. Plus I have run OKK's that were way more expensive but are crappy in comparison to Haas verticals. I doubt you would regret the purchase. |
| On Machine Inspection w/probe | behindpropeller | Haas Mills | 52 | 10-15-2011 02:44 AM |
| Newbie- Series 1 inspection questions. | bradley white | Bridgeport and Hardinge Mills | 1 | 12-12-2008 10:25 AM |
| fluoroscopic inspection machine | composites | CNCzone Club House | 2 | 02-09-2008 02:55 PM |
| Tool Inspection Machine | Smackre | Mechanical Calculations/Engineering Design | 0 | 09-25-2007 04:06 PM |
| Used machine inspection | TR MFG | Fanuc | 1 | 03-02-2006 08:48 AM |
