Pull studs – use thread locker? Good idea to use a medium thread locker on the threads of new pull studs? Or anti-seize? Light oil? Clean and dry? Mark
__________________ 2005 Haas TM-1, 4th HRT160 - OneCNC XR4 Pro w/4th - Alibre Design Expert Metal-tech 4x4 - www.metaltech4x4.com |
| It depends. If you're going to torque them, then anti-sieze or oil would be appropriate. (Proper torque according to most, by the way, is 85lbs/ft for CAT40) A lot of guys have been finding that torquing pull studs that tight will actually deform the taper on the tool holder and have been using loctite and tightening their pullstuds barely past finger-tight. I have all my pullstuds torqued to 85lbs/ft and on all of my toolholders there is a clear strip of contact at the top and the bottom of the taper, but nothing in the middle. This can not be helping the Haas rigidity issue. ![]() I'm not suggesting you do the latter, just telling you it's an option. |
| Stama MC326 Pull Studs? | awilliams684 | General Metal Working Machines | 0 | 03-16-2010 09:03 AM |
| pull studs | najnielkp | General Metal Working Machines | 8 | 06-11-2009 08:42 PM |
| Tree vmc1050 pull studs | rbpower | Tree | 3 | 03-06-2009 11:31 AM |
| Haas Pull Studs | rrbmachining | Haas Mills | 6 | 12-01-2008 02:55 PM |
| Pull Studs on CAT-40 - Basic Stuff | JWB_Machining | General Metalwork Discussion | 4 | 11-27-2008 06:48 PM |
