Old 06-07-2010, 07:46 AM
lsrengineering is on a distinguished road
setting work coordinates through program
Using a probe I have a program written to probe a tooling ball on a fixture mounted on a 4th axis and I have the values from that probing assigned to system variable #'s so I can do the math calculations to get to the actual fixture zero. What I want to do is take those values from the system variables and apply them to the g5# work offset values so when the machine is turned on daily It knows where it is. This is a setup program and only needs to be run once when the fixture is first set up.
Old 06-07-2010, 10:05 AM
Andre' B is on a distinguished road
On most Mit and Fanuc controls the work offsets are available as variables.
Code:
      Axis 1 Axis 2 Axis 3 Axis 4 ...
  G54 #5221  #5222  #5223  #5224
  G55 #5241  #5242  #5243  #5244
  G56 #5261  #5262  #5263  #5264
Locations for extended offsets are not so standard but your programming manual should have this info.
You can also use G10 to put the results in the work offsets.
Old 06-08-2010, 09:07 AM
insanedragons is on a distinguished road
Thanks Andre, i was wondering about those variables.. i hadn't read the manuals enough really.
Leased line bonded adsl
Need Help!- Yasnac MX2 work coordinates. PHD General CNC (Mill and Lathe) Control Software (NC) 4 05-14-2009 08:47 AM
G154 Select Work Coordinates Help chucker Haas Mills 4 12-13-2008 02:39 AM
Newbie- Work Planes / Work Coordinates MICFDI Esprit 9 05-11-2008 11:35 PM
losing work coordinates at power off jlong58 Fanuc 13 07-27-2007 05:31 AM
Okuma Work Coordinates firedog General CNC (Mill and Lathe) Control Software (NC) 7 06-09-2005 06:43 PM
