Old 06-04-2010, 11:41 AM
rrbmachining's Avatar
rrbmachining is on a distinguished road
Haas HRT210
Does anyone have a pdf (or a link) for a manual for the brushed type HRT210 table. I can only find the later models on the Haas site
Old 06-04-2010, 08:34 PM
Donkey Hotey's Avatar
Donkey Hotey is on a distinguished road
What kind of manual? For the controller? I don't think there is any difference between them except the cable and the type of motor.
Greg
Old 06-05-2010, 04:08 AM
Im looking for info on the rotary unit, I wont be using a seperate controller as my machine has all the 4th axis drives
Old 06-05-2010, 09:14 AM
OK, again, what do you want to know about it? Everything they tell you about it is in the current manual. It's big. It's heavy. It's made of cast iron. The platter goes 'round and 'round. Programming it on the machine is identical to the current model. The dimensions are identical. What information are you needing?
Greg
Old 06-05-2010, 12:03 PM
Well the one I have been looking at has a casing on the rear of the main body which has a lever on it which moves up and down. I cant find anything that looks like this in any version of the rotary manuals. Also some info on the cabling would be good and the functions on each pin of the 17 pin connector on the cabinet. The previous owner of my vf2 had some sort of problem and damaged the servo drive board. I am trying to get everything back working again and am being cautious before I trash another drive board, so I want to check out as much as I can before I power up
Old 06-05-2010, 12:48 PM
The pin-outs aren't in any of the manuals. That's probably service manual information only. We can scratch that off the list.
The lever thing sounds like the Haas accessory collet closer or the mini-tombstone accessory. Look at the Haas website and poke around in the rotary accessories. I think you'll find the stuff you're looking for, though all of that is also in the current rotary manual.
Greg
Old 06-06-2010, 12:16 PM
Machineit's Avatar
Machineit is on a distinguished road
Perhaps these will help.
Mike
Problem- HAAS HRT210 wiring diagram jcassidy Haas Visual Quick Code 1 03-11-2010 02:34 AM
Problem- Installing / Removing HAAS HRT210 4th AXIS glenn105 Haas Mills 18 01-21-2010 12:49 PM
Haas VF with HRT210 indexer, M21 Talisman Haas Mills 4 10-22-2009 10:02 PM
Zeroing a HRT210 Table gmh265 Haas Mills 3 08-12-2008 05:24 PM
SCO2-ACR and HRT210 TheGreenMachine Haas Mills 1 04-26-2008 10:23 AM
