Old 06-02-2010, 06:50 AM
mcphill is on a distinguished road
Helping make CAM program for a friend...
I am helping a friend with a CAM program for his Haas VF 3. At the end of this message is the start of the CAM file I made for him. The problem we are having is that the machine is going to machine home before travelling to the part home position. Can someone tell me which code to remove from the file so that it will NOT go to machine home at the start?
O100 (PROGRAM NUMBER)
(PROGRAM NAME - BLOCK2ROUGH.TXT)
(POST - HAAS VF)
(DATE - TUE. 05/25/2010)
(TIME - 04:06PM)
N01 G00 G17 G20 G40 G49 G80 G90
N02 G91 G28 Z0.
N03 G91 G28 X0. Y0.
(FIRST CUT - FIRST TOOL)
(JOB 1 ZLEVEL ROUGH)
(FEATURE Z-LEVEL ROUGH)
N04 T01 M06
N05 G90 G54 X4.1482 Y-2.5066 S499 M03
N06 G43 H01 Z.1 M08
N07 G01 X3.5422 Y-2.8115 Z.0644 F2.9947
N08 X4.4355 Y-2.362 Z.012
N09 X3.5422 Y-2.8115 Z-.0404
... rest of program runs fine...
I think he should take out the homing calls in lines N02 and N03, is that right?
Old 06-02-2010, 06:56 AM
mactec54 is on a distinguished road
mcphill
Yes that is correct take that N02 & N03 out it should not be there
Mactec54
Old 06-02-2010, 07:11 AM
Thanks for the fast reply! Will also edit the post...
Old 06-02-2010, 08:33 AM
Donkey Hotey's Avatar
Donkey Hotey is on a distinguished road
That was a safe move put into the program so an errant operator who hits Cycle Start with the spindle down near the part, won't crash into something. Why would you remove it from your post processor? How many of these parts is he going to run (in other words, how much time is really being wasted, verses screwing around with all of this)?
Greg
Old 06-02-2010, 08:47 AM
He doesn't like this move, so I will remove it for him (modify the post for him). The way he does his work is position the tool at workspace 0,0,0 and run the program from there. He is a shop owner and very experienced machinist, and somewhat "set in his ways", not an operator making 100's of identical parts...
Your comment is appreciated and warranted for "production" environments, but for this guy it is not wanted or needed.
Old 06-02-2010, 01:10 PM
CNCRim's Avatar
Put Single block on...... and find out which code is doing what.
Old 06-02-2010, 01:23 PM
Originally Posted by mcphill View Post
...... He is a shop owner and very experienced machinist, and somewhat "set in his ways", not an operator making 100's of identical parts...
I also am a shop owner and very experienced machinist somewhat set in my ways; and one of the ways I am set in is to have a Z homing command right at the top of every program as Donkey Hotey suggests.
Maybe after your friend has accidently positioned the tool at the wrong location and starts a program in incremental (G91) he will decide it is best practise to pull the tool well clear of the workpiece as a first move.
Old 06-02-2010, 01:29 PM
mcphill
If the Z was a problem then you could add were N2 was just a G0Z3.0 or what ever number he would need if he had to clear a part before a X Y move
Mactec54
Old 06-02-2010, 01:36 PM
Geof
No experienced machinist is going to use a G91 at the start of a program, if they know what they are doing
You also have a T01M6 first line of code so if it needs to change the tool then it will be up already before it will make a X Y move
Now what if it does not do a tool change, well if you have just run the program you will have a Z move at the end of the program, this will place the Z in a safe place for the next start, Like G0Z3. or what ever number is safe to clear your part for the next start
Mactec54
Old 06-02-2010, 01:55 PM
mfgbydesign is on a distinguished road
Full retract is good.
Probably a good idea to leave the N02 G91 G28 Z0 in for a full retract prior to tool change. The X and Y in N03 are what is sending it to machine home.
Contrary to popular discussion, the G91 in N02 & N03 are NOT putting the machine into incremental mode, it refers to the distance moved (in this case "0 incremental" before moving the designated axis to the machine home position via the G28 command.
  #11   Ban this user!
Old 06-02-2010, 02:45 PM
That part was really confusing me, thanks.
To some of the other posters, he does not use his tool crib (I have told him we need to get there, he doesn't do it yet). So, he does not need to do a tool change, as he preloads the tool before starting, and I only post the code for one tool at a time.
Slow and steady, we will get him more automated.
  #12   Ban this user!
Old 06-02-2010, 02:49 PM
You say he is an experienced machinist yet it appears he is trying to run a CNC one tool at a time without having a clue about preparing code. That does not meet my definition of experienced.
Helping my husband:) pmelrose General Metalwork Discussion 4 12-12-2009 11:48 AM
looking for someone helping for drawing plans. will pay draftdodger Mechanical Calculations/Engineering Design 2 09-02-2009 09:41 AM
Need Help!- Make backup off parameters and program ladder VIDE Fanuc 1 11-28-2008 08:22 AM
How do I make the program pause until it sees a TTL input? damae G-Code Programing 4 08-31-2005 07:18 PM
How do you make Bridgeport execute program? Bill Gillen Bridgeport and Hardinge Mills 10 06-14-2005 08:26 AM
