| I was running two machines today since we have work to do. Yipee! Anyway I was wondering if anyone here tries to idiot proof their setups? Today I ran a couple of parts and they were fine but loading two vises with new parts I loaded the first wrong and it scrapped it. We may be able to "fix" (weld it) maybe not. I did not set this machine up and just was distracted and running ahead of myself. Been a while since I have done that. The lead boss told me to take a clamp and put it on the moveable jaw so the part would only load one way. He said he does it all the time because he has so many irons in the fire so to speak. We also have made some of our fourth axis hubs so that when doing 2 surfaces and indexing so that the correct orientation is done preventing cutting on the wrong sides by blocking those sides with added on brackets. This is done and there is no way it can be done wrong again without a lot of noise. |
| Always reduce the chances of an incorrect set-up in any way you can. A good fixture/setup can also speed the job up. It is unlikely you will totally eliminate operator error - I remember my first balls up on CNC was putting parts up twice (I was too busy chatting), therefore shortening/elongating the ends and holes I had just done - That didn't go down too well. Try to remember these old adages when foolproofing a job: - "Never underestimate the pure genius of a complete idiot" "If it can go wrong, it will go wrong" DP |
a guy learns to be creative with idiot proofing , I worked with the idiot of all idiots , there was not a day that would go by that he wouldn't crash and destroy something , some days it was parts other days fixtures and or destroy half the tools in the magazine (literally while he stood right there ) , I can go on for a couple hrs about the stuff he trashed and how he went about it . didn't matter how well i would idiot proof cause i obviously couldn't bring myself to think his level idiocy , I'd come up with something elaborate that no one could screw up , he'd simply forget to tighten the clamps best way to idiot proof a shop is to keep the idiots out of it but then idiot proofing the job for those times that our minds may be wandering is always a good thing to do
__________________ A poet knows no boundary yet he is bound to the boundaries of ones own mind !! http://cnctoybox.org |
| Yes that was what I thought of first after I did that. I notice I never have done that if I had set up the job initially. We have been busier now a days and this is happening more. (running a job setup by someone else) I like the story related earlier because I have seen that happen also though not to that level. The bad thing also was I loaded the parts and went to the other machine and it was my lead man who started it up. He did not notice my dumb mistake and he set it up. I will just take a secound and actually focus on my task at hand. Usually I am very good at that. I will say probably the best way is to actually try to idiot proof something before a part or a run of parts gets done incorrectly. I have not been in any shop who did this as a rule of thumb though it is always in reaction to mistakes made. |
| But yes we try... I will often drill a few holes in soft jaws and press in a few roll pins to make reverse or out of position loading difficult... Operator is still able to FAIL to tighten the vise, or over tighten and distort the parts etc. |
| We have even gone as far as taking pictures of each stage of loading, laminate them and place them on the machine next to the doors so the operators have to see them, and they still manage to either not tighten something down or load something incorrectly. We even had an instance where the operator left the 3/8" hex wrench on the clamp screw and started machining. |
| Jake E. I like that! gonna use that. What I do at the moment is have every step documented, one A4 book for each machine and everything gets written down, but sometimes when an operator is pressed he'll forget to note down something important. There's nothing worse than trying to figure out what the previous engineer has done (or more importantly what he hasn't done.
__________________ I love deadlines- I like the whooshing sound they make as they fly by. |
| The latest idea we are doing is setting up a 3 ring binder including the inspection criteria (which us use screen shots form soliworks to show where to measure), loading instrucitons (with detailed pics and instructions), handling instructions (what boxes the material comes in and what boxes to put finished goods into), any Quality Alerts, Detailed information on adjustments, tool list, operation map (what tool cuts where). Then we train the CNC Tech on everything in the book (we have several Techs who make adjustmnets/changes tools etc, while we have operators who just run the machines) and record the training per ISO 2001:9000. The books are a PITA to make, but the operators and techs seem to appreciate it and they actually are referring to it. We are going to start making the same for setups as we do so many jobs, some times we forget how we set up one job that we last ran a year ago, or we have some new guys who dont know how to set it up. |
#11
| Set-up sheets/job-files...keep them concise and standardized, otherwise you end up with a mess that is more of a hindrance than a help. A picture says a thousand words, but usually needs a caption... I have seen epic tomes of information that were so vast they were either ignored or the important stuff was crowded out and forgotten. Then someone like me comes along and changes the method...even a slight change means another acre of rainforest must be sacrificed for the next edition. DP |
#12
| torque wrenches are always a good thing to have to ensure everything is tightened up consistently between operators
| Best for sound proofing? | dave6 | Glass, Plastic and Stone | 12 | 06-09-2011 12:53 AM |
| Damp Proofing Concrete Floor (workshop)? | Paragon36 | CNCzone Club House | 10 | 03-12-2010 02:05 PM |
| coolant proofing steppers | 300magnum | Benchtop Machines | 6 | 04-01-2008 05:22 PM |
| Sound Proofing Help | twistedfuse | DIY-CNC Router Table Machines | 19 | 03-03-2008 01:02 AM |
| Sound Proofing | scratch_6057 | DIY-CNC Router Table Machines | 0 | 05-05-2007 06:26 AM |
