Old 05-14-2010, 02:22 PM
mishikwest is on a distinguished road
Servo gain adjust on Z axis ?
05 vf2ss. Machine continually hums on the z axis. A tech adjusted the servo gain years ago but I certainly don't recall the #'s to adjust. There is P,D,I gain for the z axis. Anyone familiar with adjusting?
Old 05-14-2010, 02:26 PM
Pondo's Avatar
Pondo is on a distinguished road
There are 4 bit switches in the parameters for each axis that can be adjusted. They are Low pass 1X, low pass 2X, Dfilter X8, and Dfilter X4. Change them 1 at a time (either to a 0 or 1) and it will get rid of the humming. My mill had a similar issue in the Y and Z axis. Changing the parameters took care of it.
(Don't forget to change setting 7 to allow the parameter changes, plus it must be in E-Stop to change parameters)
Parameter 1=X axis
Parameter 15=Y axis
Parameter 29=Z axis
Hope it helps.
Old 05-14-2010, 02:35 PM
never mind. Fixed it. parm 29 low pass and d filter changed till no noise.
yup! thx for the reply anyways!
What would cause the z-axis to gain steps? Or appear that way? SpeedsCustom Taig Mills & Lathes 39 01-25-2009 09:06 PM
Need Help!- Failure setting servo gain TR MFG Fadal 2 12-10-2008 01:46 PM
Problem- axis gain MVIL General CNC (Mill and Lathe) Control Software (NC) 1 11-27-2008 04:43 PM
Need Help!- Fadal... Failure setting servo gain ssking Fadal 5 07-10-2008 03:19 PM
need help to adjust servo system webcruiser8 Employment Opportunity 2 11-27-2006 02:36 PM
