Old 05-13-2010, 12:10 PM
extanker59's Avatar
extanker59 is on a distinguished road
USB flash drive issue
Has anyone seen this?
About once every couple of weeks our VF-2ss won't see the program on the flash drive. It will only see the (deleted) one that was loaded just before.
On my computer, with the flash drive in the USB port, I will delete the old program then load a new one with a different name onto the flash drive.
Safely remove it, then insert it into the Haas USB port. List program and select USB device. Only the deleted program shows up. If I select it and load it anyway (hoping it was just a name issue), the old program shows up.
The only way I've found to fix this issue is to turn off the Haas and restart. Then it sees the new program.
What the heck, over.
Not a big deal but curious.
Old 05-13-2010, 07:17 PM
Delw is on a distinguished road
I load/run 5-20 programs a day in my vf2ss everyday all from my thumb drive.
What I have noticed is that mine if it has a little pressure away from you its will not read, Ie putting it in an an angle
Old 05-14-2010, 12:05 PM
extanker59's Avatar
Thanks for responding.
I don't think that's the issue here since I have repeatedly ejected and reinstalled the USB drive. This is an occasional issue since we got the machine. But, like I said, not a huge deal. Just wondered if others saw this issue.
I haven't seen the problem you describe.
I wonder if it's the drive that's to blame? No wait. The ONLY thing that fixes it is to shut down the Haas. No amount of reloading the USB drive on the computer does anything.
Old 05-14-2010, 06:50 PM
Matt@RFR is on a distinguished road
Have you tried a different thumb drive?
Old 05-14-2010, 09:57 PM
HuFlungDung's Avatar
Moderator
Sounds like a classic case of 'the operating system does not know the drive has been dismounted and remounted'. Oh, my bad, Haas doesn't behave like a Windows PC
Old 05-15-2010, 01:32 PM
extanker59's Avatar
I have tried a different thumb drive but the Haas wouldn't recognize it. Since this one worked (mostly) I stopped trying other ones.
"Sounds like a classic case of 'the operating system does not know the drive has been dismounted and remounted'." Interesting. I never thought of it like that (not a computer guy). I ALWAYS press "Origin" before removing the USB drive. Is there more I should look for?
Old 05-15-2010, 03:35 PM
mactec54 is on a distinguished road
extanker59
Before you put your thumb drive back in select a different program into memory , then do you program load
When you remove the usb/thumb drive what mode are you in when you press Origin, you want to be in the receive program mode/ usb mode when you do this
Mactec54
Old 05-15-2010, 03:42 PM
HuFlungDung
If you have the Ethernet/ hard drive option, then it is just like being in windows it is a separate computer for this option, that plugs into the machine computer board
Mactec54
Old 05-15-2010, 10:26 PM
riverracer is on a distinguished road
do you have to do this?
our haas tm2 installer never said anything about this! and it has been 2yrs of not doing any shutdown removal procedure like a pc.
have had 1 stick die on me, but i thought that it was just a crap stick, used for lots of other things not just for programs or the mill.
what is the correct removal procedure then?
Old 05-17-2010, 06:24 AM
extanker59's Avatar
Mactec54, do you mean I have to be in the List Program/USB Device screen? I am almost never there when I press Origin since I really only use the USB drive to load programs into the Haas. Almost never from the Haas. So I'd be in the List Programs/Memory or Hard Drive screens.
HuFlungDung, we do have the Hard Drive ethernet option.
Riverracer, we do have to press origin. Well, at least the screen says so every time you install the USB drive. In red letters, above the Help box on the left, it says "Press Origin Before Eject" as soon as you go into USB Device.
  #11   Ban this user!
Old 05-17-2010, 08:34 AM
Donkey Hotey's Avatar
Donkey Hotey is on a distinguished road
The "press origin" thing was on a particular generation of USB hardware and software. The manual said to do that on my mid 2007 TL-1. I had no such prompts and wasn't sure when or how to do it. A call to the factory confirmed that I didn't have to do that on my machine. Older ones with USB and/or Hard Drive/Ethernet sound like they're different.
Greg
  #12   Ban this user!
Old 05-17-2010, 10:03 AM
extanker59's Avatar
OK, thanks.
Gonna live with it. Pretty minor as things go. Still like the machine.
Thanks to all who responded.
Chris
EXITECH DSP COMPATIBLE FLASH DRIVE SIGNMAD Excitech routers 16 01-31-2011 09:24 AM
3 ½ floppy drive to USB flash drive readers scadvice General Electronics Discussion 8 08-10-2010 11:43 AM
Just IN- Acramatic Flash Drive Retrofit kit Jacob2000 Product Announcements & Manufacturer News 0 06-04-2009 02:33 PM
Newbie- demo / flash drive rsm169 NCPlot G-Code editor / backplotter 2 05-23-2008 05:46 AM
USB Flash Drive HelicopterJohn Haas Mills 30 11-23-2007 06:40 PM
