| C Axis lathe capabilities.... I was just in visiting with a customer that has 4 new HAAS machines, 2 lathes, 2 mills. The lathe has live tooling and a C axis, the live tooling uses an optioned up motor to 7.5 HP. These questions pertain to live tooling..... Can someone tell me their experiences with drilling (along the Z axis, good bad etc.) ? What size HSS drills have you used in mild steel? What about the largest taps you have used reliably? Thanks |
| i used okuma c-axis not really diy but man if you want to drill hole patterns in a turned part it's awsome!! we use carbide/Ti nitride tools... as an example, we turned a part with a threaded OD and a circular hole pattern of eight holes, each hole (including indexing the chuck) took about 12-15 sec- i did it a long time ago on a manual centre lathe and it took about 3 minutes |
| sounds like a very powerfull rotary tool spindle motor. i have tons of experience with programing/setup okuma,hitachi,,and lots of other cnc's with rotary tooling. max drilling dia with rotary tooling-25mm(1")with a pilot hole first,mat S1214(similar HP). plunge milling into the face using 25mm(1")multi tipped carbide milling cutters, i would use cad/cam for the plunging cycle and of coarse using the polar corordinate/contour generation function in the cnc. largest tapping size i can think of is 1/2 UNF into K1045.(ridgid tapping,not floating). drilling,tapping,deburring and milling in cnc lathes is very productive, check the parameters in the cnc for tapping speed double in reverse option,this really gets the cycle time up when you double the speed when the tap comes out of the hole. try and use carbide drills/milling cutters if the rotary toold are ridgid enough. hope this helps |
| CNC Glossary | CNCadmin | CNCzone Club House | 17 | 03-09-2008 04:08 PM |
| 4020 4th axis problems | little bubba | Fadal | 3 | 06-13-2005 10:08 PM |
| 7x mini lathe capabilities??? | Dan S | Mini Lathe | 24 | 04-01-2005 06:57 AM |
| OneCNC XR Series Lathe CAD/CAM Released: | OneCNC | Product Announcements & Manufacturer News | 0 | 03-07-2005 05:20 PM |
| 3 axis lathe spindle brake | atmosports | General Metal Working Machines | 1 | 07-28-2004 03:30 PM |
