Old 05-04-2010, 01:27 AM
riverracer is on a distinguished road
what does this part do?
hi,
can anyone tell me what this box on top of the tm-2 cabinet does?
it looks like it has 2 kitchen stove heater elements in it.
just wondering, as machine works fine.
thanks
ID:	106392   Click image for larger version
Old 05-04-2010, 06:03 AM
Gold Member
Ken_Shea is on a distinguished road
I've wondered that as well, going to take a guess that it functions as a over voltage take-up for the vector drive operation.
Old 05-04-2010, 06:28 AM
juxtoposed is on a distinguished road
Its a regen resistor. A motor becomes a generator when no voltage is put to it but it is still rotating, like on a decel or stop command. This resistor "uses" this voltage so it doesn't "spike" the system.
Old 05-04-2010, 06:35 PM
gpcoe is on a distinguished road
That should be the dynamic brake energy dump. As juxtoposed said, it's a resistive element and when the spindle stops, the output energy is dumped into that coil. Since the motor (essentially a generator at this point) has nothing driving it, the spindle quickly stops. If you've ever had a power outage while running you'll notice that it actually takes quite a while for the spindle to come to a stop. 5 minutes or so depending on the configuration.
One time, one of our VF-2 SS had the spindle drive fail and it applied the dynamic brake while still driving the spindle at 12k rpm. That sucker glowed bright red and caught the settled oil on the outside of that "hot" box on fire. Good times.
Greg
Old 05-05-2010, 10:50 PM
Ydna is on a distinguished road
We use it as a hotdog cooker...
Newb ? - CAD Part interference & mating part dims pabmartin Mechanical Calculations/Engineering Design 3 11-06-2009 12:18 AM
sheetmetal part? flatten a rolled part? Rich05 Solidworks 1 08-12-2009 10:22 PM
Verify Cut part to Design part. CaseyCAM NCPlot G-Code editor / backplotter 0 11-01-2008 09:22 PM
Newbie- Part holding and milling 3D part on 2.5D Mill? john_t_h General Metalwork Discussion 6 03-15-2008 06:35 AM
Missing steps on just a certain part of the part ZipSnipe Stepper Motors and Drives 5 01-02-2008 01:40 PM
