Old 04-25-2010, 02:10 AM
trangt143 is on a distinguished road
Question Cutter Compensation Problem
I have a bar part, I just cut 2 opposite sides, but cutter comp only works one side, please me.
N1 G00 G40 G80 G90
T17 M06
S760 M03
G114
G40 G00 X0 Y0
G43 H17 Z1.
M08
G00 X2.785 Y-2.
G01 Z-1.75 F30.
G41 G01 Y-0.9 D17 F1.5
G00 Z1.
G00 X-2.785 Y-0.9
G01 Z-1.75 F30.
G41 G01 Y-2. D17 F1.5
M09
G00 Z1. M05
G40 G00 X0
G49 G80 G90
G00 G28 Z0 X0
M00
ALSO
WHAT IS H#4120 , #3006= 101
I WANT TO WRITE PROBE SURFACE PROGRAM 8 POINTS USE P9811, WHICH MACRO # THAT I NEED TO CHECK, #188 IS SIDE OF BORE WHEN I USE P9814, PLEASE GIVE EXAMPLE, THANKS
Old 04-26-2010, 02:40 AM
Superman's Avatar
Superman is on a distinguished road
Your comp programming seems a little askew
You have to take up the comp on the approach side , cut your shape, then move off cancelling the comp
You are actually taking comp up on the endpoint
and moving to the next with comp still on
Code:
N1 G00 G40 G80 G90
T17 M06
S760 M03
G114
G40 G00 X0 Y0
G43 H17 Z1.
M08
G0 X2.8 Y-2.015   descend at a clear spot
G1 Z-1.75 F30.
G41 X2.785 Y-2. D17 F1.5   take up the comp on approach side
Y-0.9             comp is still on
G40 X2.8 Y-0.875  feed off while cancelling the comp
G0 Z1.
X-2.8 Y-0.875
G1 Z-1.75 F30.
G41 X-2.785 Y-0.9 D17 F1.5
Y-2.
G40 X-2.8 Y-2.015
M09
G00 Z1. M05
G40 G00 X0
G49 G80 G90
G00 G28 Z0 X0
M00
With this method, the descend in and retract out points will always be without comp and away from your shape , think if you were finishing 2 bores with a large cutter, the 2nd would more than likely crunch when descending
Cutter Compensation TravisR100 NCPlot G-Code editor / backplotter 2 10-31-2010 02:09 PM
Cutter compensation???? Clawsie Machine Cincinnati CNC 6 11-13-2008 01:19 PM
cutter compensation functionbikes Tormach PCNC 2 06-17-2008 02:39 AM
Cutter Compensation? Joe Petro Autodesk Software (Autocad, Inventor etc) 6 03-08-2006 12:04 AM
Cutter compensation? Tonenc G-Code Programing 4 11-02-2005 11:53 PM
