Old 04-25-2010, 12:02 AM
JasonR is on a distinguished road
2000 Mini Mill & MACRO's
I have two Haas Mini Mills in my shop. One is a 2001 and the other one is a 2000. The 2001 has the following macro program for serialization loaded in it.
O08010
( SERIAL # & COUNTER MACRO )
( SEE GEOMETRY WEAR OFFSET #200 FOR SERIAL # )
( .0001 WILL ENGRAVE 0001 )
#140= [ #2200 * 10000 ]
#141= FIX[ #140 * 0.001 ]
#142= #141 + 8000.
#140= ROUND[ #140 - [ #141 * 1000. ] ]
#141= FIX[ #140 * 0.01 ]
#143= #141 + 8000.
#140= ROUND[ #140 - [ #141 * 100. ] ]
#141= FIX[ #140 * 0.1 ]
#144= #141 + 8000.
#140= ROUND[ #140 - [ #141 * 10. ] ]
#146= #140 + 8000.
M98 P#142
M98 P#143
M98 P#144
M98 P#146
#2200= #2200 + 0.0001
M99
When i tried to load this program into my 2000 mini mill it produces a "Bad Code' error. I tried looking through the parameters to see if their was a function that needed to be turned on in order to use macros but couldn't find anything.
I did notice that my 2001 (with the macro working) is the yasnac (sp?) coordinate system and the 2000 is fanuc. Could that be the problem? Or am I missing an option that needs to be turned on?
Any help is appreciated.
J
Old 04-25-2010, 06:33 AM
Haas__man is on a distinguished road
There is an option that would need to be turned on.
To find out if you havve the option :
Press 'para/dgns'
Then '57'
then 'cursor down'
look about half way down the right hand side of the screen
you will probably see 'macros 0'
the '0' indicates that the option is turned off.
If you do the same on the minimill that will run the program then you should see 'macros 1'
Hope this helps.
Old 04-25-2010, 04:27 PM
Press 'para/dgns'
Then '57'
then 'cursor down'
Hope this helps.
Thank you that helps. Yes the value is set to 0. Is this a pay to play option?
J
Old 04-26-2010, 02:05 PM
Yes - you will need to speak to your HFO and find out how much it will cost.
Old 04-26-2010, 08:43 PM
$2200.00 to unlock that feature. Ya I don't think so. I would have paid maybe $500.00 for the code but $2200.00 seems a bit outrageous to unlock a feature on a 10 year old mill. I'll just run those ops on my other mill.
Mini lathe and mini mill spindle? ZipSnipe General Metal Working Machines 3 10-15-2010 08:13 AM
DM 2000 cnc mill tom in nh Dyna Mechtronics 0 03-01-2010 07:45 PM
I have $2000.00 to invest (mini Mill) jeffrey001 General Metalwork Discussion 15 07-21-2009 10:32 PM
Want to make a cnc mill for under 2000.00 sgman Benchtop Machines 19 02-19-2008 07:24 PM
X2 Mini Mill & Mini Lathe - Cummins Tools ccsparky Benchtop Machines 0 12-19-2007 07:54 AM
