Old 04-17-2010, 01:50 PM
timmydabull is on a distinguished road
keyway machining on machine
i seen some videos where keyways were being cut on a vmc using a carbide insert on a toolholder using a series of up and down plunge cut motions while inching forward to square up a machined contour.
i am curious as to which toolpath to use in Mastercam x4 and a haas tmp1 to perform this same idea.
also if i wanted to cut several keyways in the same bore along different rotations is the a way to index and lock the spindle,or will i need a rotary axis on the z axis to index the part instead of the spindle
thank you for any advice.
2007 Haas TMP-1 Microscribe MX-5 Mastercam X4 Mill Level 3 Surfaces,Solids Seagate 2 tb hard drive AMD 64x2 8gig ram windows ultimate 7 64bit Geoforce 8800 GTX
Old 04-20-2010, 12:30 PM
Ydna is on a distinguished road
I've done that before but I simply programmed it manually. one thing you might be worried about is the tool rotating during the movements. When I did it I put the machine into low gear and also knocked it up against a gauge setup to ensure it was correct. In retrospect it was barely a CNC operation when finished.
In masterclam you might be able to use that z-plunge toolpath (or whatever it's called), as long as you get it to work in a straight line. I've never used that feature before myself.
Old 04-20-2010, 02:31 PM
behindpropeller is on a distinguished road
I would call HAAS and ask if a TM-1 is strong enough to do this?
You might be better off buying a small shaper for this one task instead of ruining your machine.
Tim
Old 04-20-2010, 05:27 PM
Donkey Hotey's Avatar
Donkey Hotey is on a distinguished road
Ultimately, this really is all about chip load. If the tool is taking 0.002" shave cuts per pass, there probably isn't actually any force at all on the z axis. In fact, it's probably still falling under its own weight to take that light cut at a keyway width. There is obviously some load on the spindle bearings but, it can't be that great.
Greg
Old 04-21-2010, 11:14 AM
djr76's Avatar
djr76 is on a distinguished road
If the spindle is rotating, then there shouldnt be a problem, if its stationary then I wouldn't recommend that since it can/will cause false brinelling of the spindle bearings.
keyway cutter hpmor Surfcam 4 11-26-2008 03:18 PM
Need Help!- Using a Keyway Cutter helicaltools Surfcam 1 07-03-2008 02:20 PM
Keyway Broach Set phoodieman General Metal Working Machines 1 05-28-2008 05:04 PM
Keyway or not to keyway... That is the question jessbussert Stepper Motors and Drives 5 12-16-2007 07:14 AM
Keyway cutting itsme General Metalwork Discussion 10 05-31-2005 07:27 AM
