Results 1 to 3 of 3
Thread: compensation problem
    Apr 2010
    canada
    I am using Gibbscam to program our Haas TM3, for some reason i get an alarm when i use compensation. i have to reprogram if i want my cutter to be smaller or bigger. can you help?
    Jan 2005
    You can't comp to a smaller radius than the cutter you are using. If you are trying to machine a .25" radius, your cutter radius offset in the control can't be any larger than .25", otherwise the control will error-out.
    Registered dcoupar's Avatar
    Mar 2003
    Well, try as I might, I can't figure out what your problem is. My ESP must not be working today.
    I have an idea. Why not post the section of the code that's giving you the problem here so we can see it. It might also be helpful to know what alarm you are getting, and what value you have stored in your diameter offset.
  1. Need Help!- RAM compensation 15M
    By PTtec in forum Fanuc
    Last Post: 09-25-2008, 05:32 AM
  2. Compensation problem...
    By Jonne in forum Mach Mill
    Last Post: 07-25-2008, 06:37 AM
  3. Need Help!- tool nose compensation problem
    By Matyi in forum Fanuc
    Last Post: 03-24-2008, 04:42 AM
  4. Problem with drive speed offset compensation by PLC programme
    By toninlg in forum Servo Motors and Drives
    Last Post: 12-13-2007, 01:42 PM
