Results 1 to 3 of 3
Thread: G83 using I,J,K for Reduced Peck Cycle
    May 2006
    Quick question on Reduced Peck Cycle.
    # 56 drill 3/4" deep in 6061.
    This is the only one that I got to work however, you will see that it takes forever.
    S6000
    G98 G83 Z-.76 R.1 I.01 J.001 K.001 F3.
    I have been breaking drills off in longer I's. I am wondering if the trick is to use a longer Peck with a very low Feed Rate. This is the first time I have used the Reduced Peck Cycle and I see that within ten pecks I have reduced the Peck to 0.001". Any general pointers on how to do this better?
    Lee
    Registered dougtyler's Avatar
    Jun 2007
    You might try the G73 cycle
    Something like G73 Z-.76 R.1 F3. Q.005 K.02
    I think thats right but I cant remember exactly.
    This should peck .005 per peck, and every .02 the drill will return to the R plane to eject chips.
    Good luck.
    Moderator HuFlungDung's Avatar
    Mar 2003
    What you are telling the control is drill the first peck .01", then reduce each subsequent peck by .001" until you get to a minimum peck depth of .001, then keep doing that until the total Z depth is reached. Your figures are ultra conservative. You want enough feedrate to make a chip spiral up the drill flute. This fast travelling chip will help the flutes clear when the retraction occurs.
    I'd probably try something like this in aluminum:
    S6000
    G98 G83 Z-.76 R.1 I.075 J.025 K.025 F7.
    What Dougtyler wrote would also be worth a shot.
    Spot drill the start position so the drill does not walk.
  1. Need Help!- Peck Drill Cycle G83
    By Sam A in forum G-Code Programing
    Last Post: 02-19-2012, 05:14 AM
  2. peck drilling cycle
    By saravananraju76 in forum Hyundai Kia machine
    Last Post: 11-25-2009, 08:11 PM
  3. G99/G98 in peck drilling cycle
    By inflateable in forum EdgeCam
    Last Post: 10-24-2008, 08:21 AM
  4. peck tapping cycle
    By jdsmith0524 in forum General Metal Working Machines
    Last Post: 12-16-2006, 11:36 PM
  5. G83 peck Drill cycle
    By Vaughan in forum G-Code Programing
    Last Post: 03-19-2004, 12:11 PM
