I have machined up a rectangle bar, bored with a 32 mm hole in the middle., The total length of this is 210MM A hole is bored in the middle and is bolted to a 40 taper tool with a 32 MM spigot, A tool holder is mounted on one end and i Balanced the Tool on Knife Edge jig, From a Grinding Machine,(static Balance) With a PCD Tip what is the Maximum RPM i should run this tool? I am fly cutting Alloy Motor cycle heads with it, I am wanting a mirror finish on my Motor bike Alloy Heads, js |
| Your tool sweeps out about 0.67 metres per revolution. I found a reference which mentions PCD as being able to cut aluminum at 5000 m/min, so I think your cutting speed limit is probably how fast your machine can run. However I suggest great caution. You have statically balanced your tool but dynamic balance is likely to be a whole different thing. If you have a 32mm hole your bar must be fairly big and heavy. It could create a lot of mayhem if it comes loose at a high speed. Personally I would not spin a tool like that faster than about 1000 rpm and even then I would be very nervous about the polycarbonate windows keeping it inside the machine if things went wrong.
| Not to disagree with you but a mirror finish is not a good thing for a surface that will be sealed with a gasket. You need a smooth finish but a mirror finish will allow the mated surfaces to slide on the gasket as the engine heats up and start leaking. If you look at brand new parts they aren't a mirror finish. Just from my own experience from working part time for a while in an automotive machine shop. cary |
I ran the Rectangle fly cutter on the HAAS, I will not go faster than 1000. I do not want to harm the spindle bearings, there is a surface finish measured in a value Called Ra most of my bikes are AIR Cooled, so there is not a issue with water, I tried a sweep on a block of alloy , 100mm wide X80MM long, spindle In the beginning ran at 500 rpm, The Finish is like Glass, I have been surface grinding the alloy heads in the past, i used a special wheel that does not clog, The fly cutter took a long time to make, All up Cost me $600.00 Well worth the Expence, js, |
| packrat is right as far as sealing... your not sealing water but air/fuel mixture on the compression cycle...if it leaks you produce less power. unless your running a lot of parts slower is better for this job. |
| Cutting speed locked to Z torch height control speed | Beefy | Mach Plasma / Laser | 1 | 02-14-2010 05:14 PM |
| Is cutting speed limited to Z-axis speed | Beefy | CNC Plasma and Waterjet Machines | 4 | 02-13-2010 04:06 PM |
| Cutting speed | locky2701 | Mazak, Mitsubishi, Mazatrol | 3 | 01-23-2009 02:11 AM |
| Need Help!- Plasma Cutting Speed | Profpinz | CNC Plasma and Waterjet Machines | 3 | 11-14-2008 08:15 AM |
| How to speed up arc cutting? | Hack | TurboCNC | 11 | 11-06-2005 04:38 PM |
