We have two Haas CNC mills, a TM1 and a TM3. Both are on the network, we basically dump programs on the CNC machines hard drive and run them from there. Problem is you can't edit programs on the hard drive. I went through the manual and looked through old posts but could not find a way to copy the programs from hard drive to memory. What I have found is the following information; Select program in Hard drive Go to memory, it shows the program below and the destination as memory Press F2, nothing happens. If I give it a program name say O0111 and save that, then try to type F2 it responds error no program name. Does anyone have a good step by step on how to move programs from the hard drive to memory? Thanks Steve |
| When I do the above is says: CAN NOT COPY I Made sure it was not the program currently being used, still the same result. Is the format of the program not correct for it to copy it? |
| I just tried it on our VF2-ss. Step by step it's Go into Hard Drive on the CNC Highlight the program you want Press Write Left arrow Go up to Memory Right arrow Press F2 That's it. Worked just now on ours. Could there be something else wrong? Maybe no O# at the begining of the program in the Hard Drive? (Don't know if that's even possible-just throwing it out there) |
We use visual mill and I double checked the post processor and I don't see anything where I can check off that it should include a name for the program. I went and used a text editor and add one. That did the trick. I have never run programs from memory either (except warm up) and run from the hard drive even for our 3D mold files. But these are two little repeat secondary operations jobs that it would be nice to keep local to the CNC machine. Thanks for the help! Now I need to hit the Visual Mill Forum and ask if anyone knows if in the depths of visual mill there is a way to add a program name and number to the output. Thanks again! Steve |
| acramatic 2100 hard disk copy | mtcalireza | Cincinnati CNC | 4 | 04-20-2011 02:59 PM |
| Hard Drive | larry53 | Computers and Networking | 13 | 12-16-2009 06:41 AM |
| Problem- Can't copy ALL programs from memory to USB... | Mike Braddock | Haas Lathes | 9 | 03-23-2009 10:42 AM |
| hard drive on cnc | keithmech | General Electronics Discussion | 1 | 08-26-2008 09:06 PM |
| Hard Drive | larry53 | Computers and Networking | 5 | 01-04-2008 03:19 PM |
