Hi all. The 20/15 vector spindle drive of our VF2 is dead, according to the technician. Does anybody know of any company that might repair this drive?. I want to try to avoid the cost of a complete new one, suggested by the technicia. Thanks a lot for the help. |
| The vector drive is full of common, industrial parts (at least in the USA). The only piece in there that could fail that is not commonly available is the logic board. There is a DC power supply inside that is known to fail. The capacitors could short. The contactor could go bad. The main IGBTs or the braking IGBT could go bad. The rectifier bridge could fail short or open. All of these components have screw terminals or plugs and are easily replaceable. The problem is being comfortable enough with electronics to diagnose each of them and determine which might be bad. You might be able to get somebody in Argentina to fix it unless you're truly comfortable taking it apart and trying to repair it. What exactly is happening? What error numbers?
__________________ Greg |
| Thanks Greg. According to the technician, the problem is in the triggering stage of one of the IGBTs. Apparently it is a hybrid circuit designed/manufactured by Haas which is not sold separately, and it seems that it is not possible to know what kind of circuitry is inside of it. That is why I'm looking for someone mainly in USA who could probably repair the drive. Thanks again. |
| OK, yes, if that's true, it's probably not repairable by anybody. Haas doesn't even sell that version of the Vector Drive anymore (my first one failed and the replacement is a new design). The IGBT trigger circuitry is part of the main logic board. It's all surface mount technology and it's complicated to repair. That's why I doubt anybody can repair the drive if that's truly the problem. Of course, this all assumes that the diagnosis was correct. If he was wrong and it's just a bad IGBT, the drive might be very repairable. It might be that the DC power supply inside might be failing and not supplying enough current for the logic board. That might look like a logic failure but, not be. I'd say that your options are:
| Try this company out of North Carolina: http://www.industrialelectronicrepai...ive_Repair.htm I have not used them or endorse them at all but thought I would check them out some day if the need came up. Research them and let us know your feedback as many would be interested. Good luck with the repairs. |
| crococh, Was this a Haas technician and how did he come to the conclusion that is a problem with the IGBT? Vector Drives are technically "not field servicable" according to Haas factory, so most techs just verify that it is dead and replace it. |
We have a repair facility for vector drives. Have you sent your out for repair? Let us know if you are still needing this repaired - Precision Spindle & Accessories Inc. www.precisionspindleinc.com tel. 519 671 3911 haviland@precisionspindleinc.com fax. 519 652 5994 |
| Sharing my Haas vector drive schematics | tayfunk | Haas Mills | 7 | 01-12-2012 02:35 PM |
| Need Help!- Haas 123 Spindle Drive Fault question | mikshaw | Haas Mills | 3 | 05-05-2009 09:31 PM |
| Need Help!- haas vector drive 20/15 hp | paul emblem | Haas Mills | 3 | 09-18-2008 05:44 AM |
| Haas Vector Drive 20/15 Need Help | tecko | Haas Mills | 6 | 02-22-2007 08:17 PM |
| Haas Mill, Vector Drive | DEAN | Haas Mills | 1 | 03-17-2005 04:05 PM |
