Old 02-26-2010, 01:37 AM
*Registered User*
0alex is on a distinguished road
Ethernet and rs232
hello,
I do an interface with a machine haas mini mill
Can I use the Ethernet port as the port rs-232 with the same commands? eg Q600 and Exxx
Old 02-26-2010, 02:45 AM
*Registered*
LEVONCNCDUDE18 is on a distinguished road
My cnc driver and stepper motor ,,when i jog, left and right only left is always running,it should be runs in different direction always left .......i knew there is a jumper on the main board for setting a direction.i try to set to right direction , i moved the jumpper ,,,, its the same problem, it jog always right dir ..
what do you think
Hurco KM1 RS232 to USB OR RS232 to PCMCIA solution? modernprecision Bridgeport and Hardinge Mills 1 09-11-2008 01:15 PM
Ethernet ?? a5sniper Fanuc 1 12-07-2007 03:52 AM
VF-1 + Ethernet frogger Haas Mills 9 10-07-2007 07:07 PM
Ethernet TURNER Fanuc 8 12-20-2006 04:36 PM
DNC over Ethernet/RS232 Terminal servers tricky Machine Problems, Solutions , Wireless DNC, serial port 1 11-04-2005 10:08 PM
