Hi every one, surfcam has a post for a haas mill with tool description, does any one know of post for haas lathe with tool description or how to make one of my own. They work so well when you pull them up on the machine later and you have no setup sheet. Thanks Jerry
I know with the lathe post on surfcam, much like the mill post, you can add descriptions in the tool path menu, my suggestion would be to do that. Although i do believe there is a setting in the S-post for surfcam that will let you enable that. im not for sure on that though.
