Results 1 to 4 of 4
Thread: Have basic ?s about Set-up, and Display Positions For Hass SL Lathe.
    Jul 2007
    I've started a new, part time job. I was setting up the machine last night and noticed a couple of things. First off, I had to use a 1" block to help touch off "Z" on the face of the chuck, and I have no way of touching off on the OD of the chuck to pick up "X". Without making a skim cut on the part.
    I was wondering what other methods are there for picking up "X", if any?
    Now for the important question, what do need to do to show the actual location of my tool, when I call up the tool using G54 T0202, or when I'm running the program? I want to see what Dia the tool is at and what the Z distance is for my "Z" zero location.
    Also, is there any helpfuls anyone can share with me?
    Thanks.
    Jul 2005
    Unless you have a toolsetter the only way I know to do the X offset is like the manual description; take a skim of the OD, press X offset key, measure the diameter of the skin and enter it. I also do the same for Z; skim the end and set Z to that then touch all the other tools off on this face.
    For displaying where the machine is at go the the Current Commands page and then push cursor up (^) until you see the Position Work display in the upper right corner of the screen.
    Registered CNCRim's Avatar
    Feb 2006
    Yes, if money is not a subject, then get a 3D touch probe(pix below), pick up X Z Y blah blah.
    Attached Thumbnails Attached Thumbnails Have basic ?s about Set-up, and Display Positions For Hass SL Lathe.-3dtaster1.jpg
    Jan 2006
    Riverside,CA
    I will sometimes use a piece of paper between the tool tip and the chuck or a piece of tooling of a known diameter. Carefully move the tool up to the chuck until you can't slide the paper between them anymore and then set the tool as if you have taken a skim cut. Its not perfect but you can get pretty close.
  1. Problem- Hass P-Coolant
    By Joseph Souza in forum Haas Mills
    Last Post: 10-30-2009, 01:54 PM
  2. Newbie- can some one show me what a facing program looks like for a Hass Lathe.
    By bobrob in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 03-16-2009, 12:03 PM
  3. Max Min Positions Help
    By JWB_Machining in forum Haas Mills
    Last Post: 10-30-2008, 10:04 AM
  4. Basic Fanuc Lathe Postprocessor
    By rishi_j in forum Post Processor Files
    Last Post: 01-22-2008, 06:10 PM
  5. CNC Mill & Lathe Positions needed
    By MachineHouse in forum Employment Opportunity
    Last Post: 10-18-2005, 08:54 PM
