Shims if necessary although I think you can shim the entire turret assembly to get the bottom of the tool pocket at 0.750" below center so most standard good quality insert holders will put the tip on center.
Just a hint: Retrofitting the Servo driven Turret is not a simple operation and needs new software and modification to Parameters. Make sure your local Haas dealer is up to speed on this, if they have not done it before make sure they are not charging you for all the learning time. I had one installed and the actual installation running cables and aligning and bolting the turret down takes about 3 to 4 hours; however, it then took several hours of fooling with software and talking to the service people at Haas Automation to get the software loaded and running.
LinkBack URL
About LinkBacks
