Results 1 to 3 of 3
Thread: Haas live tooling keeps faulting out
    Apr 2008
    Question Haas live tooling keeps faulting out
    Trying to drill a 3/4 drill bolt hole pattern machine wont do it i have had to slow it down to .4 ipm and iam using g83 peck and carbide drill . This lathe just cant handle it , i guess vl 40 anyone else have this problem suggestions ?
    Feb 2007
    Do you have the live tooling high torque option on your machine?
    APP
    APP is offline
    Sep 2006
    Seems something is wrong.
    I don't have the high torque option, but have tapped 1" deep m16 tap through 4340 with no problem.
    Is it alarming because the spindle isnt locked? I have had problems with big drills if the the spindle brake is not on. Spindle orientation works fine for smaller stuff, but the gear motor is moved in place with an air cylinder, and with enough load will compess the air and slip. Use the brake.
  1. looking for live tooling
    By supreme in forum Want To Buy...Need help!
    Last Post: 11-27-2009, 12:34 PM
  2. What is Live tooling versus "non-live tooling"?
    By squale in forum General Metal Working Machines
    Last Post: 11-15-2007, 03:38 PM
  3. SL-20 live tooling
    By stefan2108 in forum Haas Lathes
    Last Post: 11-02-2007, 03:50 PM
  4. Haas OL-1 Live Tooling
    By Jorge-D-Fuentes in forum G-Code Programing
    Last Post: 07-17-2007, 02:09 PM
  5. haas live tooling
    By tgooding in forum Haas Mills
    Last Post: 12-06-2006, 08:58 PM
