Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Haas Lathes
Haas Lathes Discuss Haas lathe here!
Old 10-27-2009, 07:34 PM
J-Mccoin 2009 is on a distinguished road
haas SL-20 to Haas bar 300 alignment plate needed
does anyone have a haas sl-20 with a barfeeder on it?
i need the alignment plate that bolts and aligns the barfeeder to the lathe..
anyone have one laying around or one that they can use as a blue print to make me one? the plate must be off a sl20 haas to work..
thanks jeremy
765 499 1875 or jlmmachine@earthlink.net
Old 11-20-2009, 03:14 PM
double a-ron is on a distinguished road
Hey, I just bought a tl-15 used, it also came with the bar feeder but the plate did not show up with the machine. I simply aligned it by eye then cut out two plates on my water jet to bolt it to the floor. Honestly I don't think it even needs to be bolted down, the machine is heavy enough and the bar feeder is not light so I doubt it would ever shift during normal operation. If you jam a bar it might move but you would most definitely ruin the push rod and a shifted bar feeder would be the least of your worries. A piece of advice if your new to the servo bar 300, replace the low rent plastic bushing the push rod slides through at the front of the feeder with a bronze one. Also I swapped the dinky 3/8 push rod for a 1/2". Also the spindle liners Haas sells a over priced and worthless. You can make your own out of pvc or drop alu. tubing for a fraction of the price.
Old 12-02-2009, 10:13 PM
03clipse is on a distinguished road
I have a mini lathe with the servo 300. neither is bolted down.the plate is really not needed. ours has been knocked around several times by a fork lift. I just bump the other side and tweak it till a bar loads without getting hung up.
Need Help!- Haas Post needed inertialabs GibbsCAM 6 01-02-2012 11:02 AM
Newbie- Haas TM-1 Post processor needed keithki SolidCam 6 06-06-2011 02:25 PM
Haas Super Mini-Mill and Haas Trunnion Table Gabe Newell Haas Mills 6 06-07-2009 02:23 PM
Face Plate for Haas TL-1 (A2-5 Spindle?) JWB_Machining Want To Buy...Need help! 0 04-24-2009 03:03 AM
Haas VF-2 tool changer alignment. hutch07 Haas Mills 2 09-03-2007 10:27 AM
