Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Haas Lathes
Haas Lathes Discuss Haas lathe here!
Old 10-21-2009, 11:36 PM
Tucker84 is on a distinguished road
chamfer into radius
how do i program a .25 radius off of a 30degree chamfer without G41 or G42? it blends to a 90 up the face of the part. when i graph it on the control the radius looks odd. i'm not using any cam software, programming it manually. thanks.
Old 10-22-2009, 07:45 PM
positiverake is on a distinguished road
Is this a haas control? if it is you'll probabley have to do the math,I dont think the auto radius/chamfer will work unless its a 90 deg corner. try using the trig calculator, I don't think haas has blue print programing were you can use angles,radius and comma's with the X/Z moves, to bad..it works nice when you have a angle into a radius. you'll still have to program for the tool radius if you dont use cutter comp.
Old 10-24-2009, 12:41 AM
Yeah its a haas. I actually called a machine shop down the road for help and they used gibbs cam to program it for me but i would still like to know how to figure this out with a calculator thanks for your help
Old 10-25-2009, 01:52 AM
I would try the trig calulator on the haas control,this will give you the points but I dont think it will give comp. numbers for the tool radius, I might be wrong? if you dont know how to use it ,look in the programing book or call haas. heres a link for the old school way of doing it. good luck.
http://www.rose-training.com/tandp/aug04.htm
Old 10-28-2009, 09:26 PM
SBC Cycle is on a distinguished road
This is the way I used to program arcs and angles on my Cincinnati. On the Haas I use G41/G42 if I'm feeling lazy.
Thanks for the link, my notes are getting torn and tattered.
chamfer into radius Tucker84 Machinist Feedback 8 12-05-2009 11:20 AM
"Radius to end of arc differs from radius to start on Line #" labuda G-Code Programing 8 11-15-2009 07:35 AM
2D chamfer jcnewbie Mastercam 5 10-19-2009 12:06 AM
Need Help!- Radius to end of arc differs from radius to start? Jamy LinuxCNC (formerly EMC2) 2 08-23-2009 12:28 AM
Chamfer CharlesM479 Solidworks 3 04-12-2007 12:13 AM
