Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Haas Lathes
Haas Lathes Discuss Haas lathe here!
Old 10-18-2009, 09:01 PM
hercules is on a distinguished road
Can I index the spindle on a TL-1?
I have a one off project that would require me to index the spindle on my TL-1 and then have it hold, then index again and hold etc. Can I do that on this machine? If so can someone explain briefly how? I would appreciate the help, I have never tried anything lke that.
Hercules
2008 TM-1, 2008 TL-3, 2009 TL-1, 2010 VF-2YT
Old 10-19-2009, 12:27 PM
pit202 is on a distinguished road
try M19 code with a Pxxx when works check the manual.
__
Peter
Old 10-19-2009, 12:42 PM
underthetire is on a distinguished road
TL1
Don't think so. Usually only live tool lathes can. Our TL1 can not for sure. Pretty basic machine.
Old 10-19-2009, 02:50 PM
SlowRiderr is on a distinguished road
Have you thought of making a fixture or something like a simple indexer?
Old 10-20-2009, 09:48 AM
swain is on a distinguished road
Index
Don't know about a TL-1...
But I do know that if you buy the bar feeder with your lathe from haas,
spindle indexing is included. They do it so you can index the spindle for
hex stock bar feeding.
I have it on my SL-20...they didn't turn it on from the factory...but the
codes were in my setup papers...so I had service guy turn it on when they installed machine.
S
Old 10-23-2009, 11:00 PM
Thnaks guys I figured it out. I was searching in my manual and on the net for TL-1 "spindle indexing" since I was thinking of an indexing head. Turns out I found they call it "spindle orientation". So I turned on the 200 hour try out option for "spindle orientation" and then used M19 Rx.xx and it worked perfectly. Got my part made and only used up about 2 of the free 200 try out hours.
Hercules
Old 10-27-2009, 11:06 AM
Wiseco's Avatar
Wiseco is on a distinguished road
Don't forget to turn the option off after using it to not loose your 198hr. And you must reboot the machine after that.
Has anyone here used 1st INDEX ? DaveJ-FTM Vendor Discussion 0 04-15-2009 01:21 PM
Spindle RPM control - Do I need an index pulse? Lexx0001 LinuxCNC (formerly EMC2) 8 03-27-2009 02:42 AM
rw14 - Spindle will not index on toolchange 66 AC COBRA Milltronics 2 04-16-2007 11:51 AM
Taig / Digispeed XL spindle index sensor Dfennell Taig Mills & Lathes 1 01-02-2007 12:23 AM
spindle index, encoder, home/limit switch Wm McNett General Electronics Discussion 10 01-13-2006 07:39 AM
