| Haas Lathes Discuss Haas lathe here! |
| Here's a good description straight from Haas: www.haascnc.com/CNCMag/PDF/v11i38.pdf (page 48) |
Well, first non-monotonous ... meaning that either the X or Z axis does not consistently grow in the same direction. Take for instance a shaft with three OD diameters ... say .500, .750 and 1.00 respectively ... the X axis is always growing from the centerline in the same direction ... now say that the diameters are .750, .500 and 1.000 respectively ... this is non-monotonous because the X goes from .750 down to .500 then up to 1.000 ... the diameters don't grow in the same direction ... similarly, the Z axis works the same way. There is a Type I and Type II canned cycle for G71 and others ... Type II is an option. You can invoke the Type II ... or get an alarm ... by incorporating an X and Z move in your first move within the P and Q sequence numbers. Sometimes just a U0 or W0 will do the trick. For example : Type I : N1111 G00 X1.000; Type II : N1111 G00 X1.000 W0; You will get a different alarm if the Type II option isn't there ... in which case you can't use the G71 to make your non-monotonous part. Hope this helps ... Real World Machine Shop Software at www.KentechInc.com |
| Post the code that is giving you a problem. The Haas manual does not explain non-monotonous very well but if you get that alarm you have selected type I but as bluechip mentions you can select type II by having both X and Z moves on the P line. On a TL2 type II is available
That is correct. Your start point ahead of the G71 line has to be a larger diameter than the largest diameter in the shape and then on the P line put in both X and Z moves. If you are doing arcs, G02 or G03 using R and get them mixed up, or have a wrong R value you may cause a non-monotonous alarm because the arc is trying to go outside the diameter limit set by your starting point. This can be confusing because the error is in the arc command and is not immediately obvious.
| NEED HEELP ALARM #414 Y AXIS SERVO ALARM? | PICMAN | Fanuc | 6 | 04-29-2011 06:20 PM |
| Need Help!- 750 ALARM SPINDLE-1 ALARM DETECT (AL11) | PICMAN | Fanuc | 9 | 03-27-2011 07:14 PM |
| ALARM shuttle drawbar alarm haas | timmydabull | Haas Mills | 27 | 10-30-2009 09:27 PM |
| Need Help!- DAEWOO 8 Steady rest pressure alarm, External feed hold alarm | doubleeagle | Daewoo/Doosan | 4 | 06-12-2009 04:15 PM |
| Problem- Alarm 350, not in my alarm list, any ideas? | ralph@nes | Mazak, Mitsubishi, Mazatrol | 4 | 09-27-2008 02:14 PM |
