Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Haas Lathes
Haas Lathes Discuss Haas lathe here!
Old 09-18-2009, 04:45 PM
vegas705 is on a distinguished road
Touching tools off of workpiece on SL-20
This is on an SL-20 Lathe
How do you touch a tool off of the work piece in z axis such as a drill or a tap. I tried to touch the tool to the workpiece in the tool offset page push z face measure but my offset changs from -8.6584 to -13.1182.
Is there another procedure to touch off tools in z axia besides the tool pre-setter
Thanks in advance
Old 09-18-2009, 08:55 PM
Do you have any values in G54?
What you describe is the way Haas says to do it; if the face of the work is going to be Z zero just touch the tool to the face and push Z face measure. With drills for X you just push F2 and it brings up the X zero position for the centerline of the machine.
Check that there is nothing in G54 and it should work.
Old 09-18-2009, 09:35 PM
Do I need to touch all tools off or can I just touch off the longer tools that will not meet the pre-setters restriction in size
Old 09-18-2009, 09:37 PM
Yes there is a offset value in g54 should i set that to 0.00. also once all tools are set can i still use g54 or do I need to use another offset such as g55 or g56
Old 09-18-2009, 10:41 PM
Go into your Settings and find Setting 64 T. OFS Meas Uses Work.
I think you will find it is OFF.
Turn it on and now when you use Z Face Measure the value in the G54 offset will be subtracted from the work offset value that goes into the work offset table.
Then you can use G54 as you have been doing.
I think this is correct, turn your rapids down and single block to make sure things are the way you want.
Old 09-18-2009, 11:14 PM
Thanks I will do it tommorow let you know how it works. I d id not know about setting 64 that is a good piece of info
Old 09-22-2009, 09:14 PM
Works well if you are going to touch all tools off of the work piece, your work offset (ex G154 P1) and G54 needs to be 0.000, If you are going to touch only 1 or 2 tools off of the work piece due to lenght your G54 value needs to be the same as the work offset you are using ie: G154 P1
Thanks for the Great Advice
Workpiece coordinates jeffm General CNC (Mill and Lathe) Control Software (NC) 2 11-10-2008 07:43 PM
Newbie- Touching-off bloefeld Haas Mills 4 08-03-2008 06:07 AM
automatic touching off of tools and x/y alignment? josh591 CNCzone Club House 4 07-13-2008 12:52 AM
Setting Z Zero at Top of WorkPiece? jlhersh SprutCAM 1 12-04-2007 05:40 PM
Cylindrical workpiece MAX711 SprutCAM 7 12-03-2006 09:11 PM
