| Haas Lathes Discuss Haas lathe here! |
#13
| Somewhat unrelated to the topic, but if I want to shift all my Z offsets 1/2" closer to the spindle face I would enter -.500 in the G54 Z offset column, correct? Right now X & Z are set to 0.0. Also if I were to enter .002 in the X wear of tool 3, would it change the dia. of the part by .002 or .004? Thanks, Greg B. |
#14
| Yes, -0.5 in G54 moves everything toward the chuck 0.5. Does wear apply to radius or diameter? I think it is probably diameter because the X offset values are diameter.
__________________ An open mind is a virtue...so long as all the common sense has not leaked out. Last edited by Geof; 09-18-2009 at 10:53 PM. Reason: Forgot the minus sign |
#16
| I know on a mill that compensation has to be active for wear to work but on a lathe I so rarely use either compensation or wear I don't know if it is the same. And I am too lazy to pick up my manual and try to find it.
#17
| Looks like you don't need comp turned on to use the wear column. I changed the X wear by .010 and got a part that was .010 bigger on the dia. Entered a -.004 and got the part - .004. Anyway, thanks to all the help I've gotten, I was able to accomplish this on Saturday morning. ![]() ![]() So, I'm pretty happy. But I know this is just the tip of the iceberg, so to speak. These are relatively simple parts, I know. But for the first thing I've done on a CNC lathe.....well you know. Greg B. |
| Newbie- Takeout Unused G Code commands in Mastercams Generated G Code | shneek | Mastercam | 8 | 12-15-2010 02:32 PM |
| Hardinge threading code | Pontiff51 | General Metalwork Discussion | 3 | 03-16-2009 11:37 AM |
| looking for g code 3d from bobcadcam or simmilar for indexer lpt v5 with g code soft | troyswood | Ability Systems - LPT Indexer and G-Code | 2 | 12-24-2006 09:21 PM |
| CNC Lathe Threading G-Code HELP>>>> | vtech99 | Coding | 2 | 08-26-2006 03:30 AM |
| G-code to control double threading! | samirnashef | G-Code Programing | 4 | 08-13-2006 06:29 PM |
