Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Haas Lathes
Haas Lathes Discuss Haas lathe here!
Old 09-09-2009, 12:34 AM
Sachn is on a distinguished road
MQL in Haas SL20 ?
I am almost on the verge of finalizing a Haas SL20 to add to my setup. I am wondering if anyone here has used or is aware of Minimum Quantity Lubrication (MQL) on a CNC lathe.
I am beginning to find coolant in all machining operations to be messy and was wondering if anyone here has it implemented in their lathe.
I usually machine low-carbon alloy steel (SAE 8620) and the like and operations are mainly general turning and drilling, very little of threading or grooving.
Regards,
Old 09-09-2009, 09:22 AM
HelicopterJohn's Avatar
HelicopterJohn is on a distinguished road
MOM
Haas does offer an option on their mills called MOM (Minimum Oil Machining), I am not sure whether it is available on the lathes or not.
You are welcome to visit my website www.helicopterjohn.com and look at some of the videos that I have made to describe some of the lubrication/chip removal systems that I have designed for use with my HAAS TM-1P. Just click on the gallery button at the top of the main page to access the videos.
The videos may give you some ideas for a system that would be helpful in your lathe operations. The controls are pretty much the same on all the HAAS machines. I am not sure about the lathes and how many M function relays come standard.
John
haas sl20 ashro Haas Lathes 2 07-24-2009 08:52 AM
HAAS SL20 and HAAS VF2 ProE Posts? CNC_student Post Processor Files 5 07-10-2008 03:46 PM
Need Help!- New Haas sl20 control bullseye Haas Lathes 35 04-16-2008 09:39 AM
HAAS SL20 programmers help HAASboi Haas Mills 4 05-05-2007 09:39 PM
HAAS SL20 Problem BobAllen Haas Mills 8 01-04-2007 04:55 PM
